Keep losing signal tv - Televison & Video
My Sony bravia tv keeps losing connection to the Media server (computer) I can reconnect but it keeps happening randomly daily Please help
Hi there.
I assume that you are connecting wirelessly. The most common problem is that the TV is at the outermost range of the wireless signal from your router/AP. try moving the router/AP closer to the TV. However I would recommend that you use a lan cable rather as this is a more reliable connection. You will also need to check your network settings. To keep the network connection more stable make sure both the TV and media server have static IPs, especially the server.
Feb 03, 2015 | Sony Televison & Video
Why does my TV screen keep cutting out
do you lose the audio signal when this happens ?
Sep 05, 2014 | LG Televison & Video
Keep losing signal
You have a weak signal. There are many possible reasons for this, such as:
The aerial has moved or there is a poor connection.
You are tuned to the wrong transmitter.
Aug 05, 2014 | Humax Televison & Video
My tv keeps losing signal. Y?
Lose of luminance signal should be the fault to its main processor board.
Mar 17, 2013 | Televison & Video
My tv keeps making a loud clicking noice
Does the set just click on and then right back off? Do you have Flashing power Light on Front or is TV playing with Loud Clicking?
Oct 07, 2012 | Sony SELECT KDF-E50A12U Rear Projection...
Phillips 32pfl5522d/05 signal problem
Call your tvs manufacturer with all the serial numbers and such easily available. They should be able to either answer your question or tell you who can. Good luck. -SB
Feb 01, 2012 | Televison & Video
301 dish keeps losing signel
If keep losing signal, but comes back, then your dish likely has become a bit loose on its mount. That, or the LNB's screw has fallen out.
You could also have trees growing into the beam (those this usually only causes problems in spring when leaves sprout out). Your coax could have moisture getting into it somewhere, or is damaged by a tight bend.
Nov 02, 2009 | DISH Network 301 DTV Receiver
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
My samsung PS50C96HDX keeps losing signal
Do you have Dish network or Direct TV? If so it is your Dish that is loosing the signal. Or your TV cables are not connected tight on the system.
Apr 03, 2008 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
