Question about VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - Biscuit
Vitra 1.6 Gpf/6.0lpf how to remove tank lid - VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - Biscuit
When the toilet back is removed does the seal need to be replaced?
Yes the rubber gasket between the bowl and the tank should be replaced, because it takes the imprint of the flush valve and ther's no way to make sure it goes back in exactly the same place, so it could leak, They are not expensive and should be replaced, along with the tank to bowl gaskets.
Jul 12, 2014 | VitrA Aria Toilet with Round Bowl /...
I am trying to find a replacement cistern lid for a Vitra, can you help?
Hello. Call your local plumbing shops. Some of them store all of the used parts for this very purpose. If they don't have a lid, they may have a source nearby. Joe
Oct 12, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Vitra 1.6 gpf toliet, filling every 20 minutes Is there any leak?
Well, yes, there must be a leak. look at the flapper valve for build up or distortion/ deterioration.
Oct 10, 2010 | Home
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Toilet lid is broken, is there a way to find a replacement
Any normal toilet seat may work, check your local Home Depo.
Mar 23, 2010 | VitrA Aria Toilet with Round Bowl /...
Replacement part for VitrA cistern
I trust you mean the "Flapper Valve". They are available and most hardware stores.
Get a Universal type as they fit most units. Take the old one with you. If you turn the water off at the wall it will stop it from running while you're away
Nov 26, 2009 | VitrA Aria Toilet with Elongated Bowl/...
We have a broken tank lid and need to replace it.
Try your local plumbers merchants [u need the make of the toilet] or thy local salvage yards www.salvo.com could be helpfull
Always take the broken lid with you
Sep 07, 2009 | VitrA Aria Toilet with Elongated Bowl/...
Open Questions:
Water seeping into the toilet bowl Hi Sir/Madam, I have Vitra floor mounted toilets (x3). Currently, one of them is having water leaking problem (water flow to the pan. I believe it is to do with the worn-out washer, but because it was extremely difficult to source the spare parts for Vitra (even through Galvins - the recommended stokist for Vitra products), the plumber suggested me to change the whole mecha nisms inside the tank, and Geberit spare parts was installed after much 'improvisation' from the plumber. However, after a year, the water leaking is backed again. I really want your assistance and instant response to tell me where can I get the genuine parts for Vitra, the entire mechanism in the water tank in order to stop the water from flowing to the pan. I too have a question here: This is the wall-faced toilet suite and the tap water is built inside the tank. Plumber told me also that there are a few fine hair-liked cracks underneath the ceramic/china tank, is it the cause of leaking even though the new Geberit mechanism has been changed a year ago? If so, is it possible to just change the tank rather than replacing the whole toilet suite for other brand whereby parts are easily sourced such as Coroma or Fowler(in the case of Australia) as my toilet is still look new and well maintained (except for the leaking). I desperate want your professional advice to treat this long-pending water leaking problem. Please do tell me where can I buy and/order the parts in Australia. Which country on earch can I order the parts from if none can be acquired in Australia. Thanks very much for your time and assistance in this matter. Kind regards, Angeleen Yong (Resient from Western Australia)
Nov 30, 2011 | VitrA Aria Toilet with Elongated Bowl/...
See all VitrA Aria Toilet with Elongated Bowl/ Flat Tank Questions
VitrA Aria Toilet with Elongated Bowl/ Flat Tank Lid - Biscuit Logo
Top VitrA Home Experts
jasbo
jasbo
woodzowl307
mrbill99
Level 1 Expert
Are you a VitrA Home Expert? Answer questions, earn points and help others
