Question about Archery
Manual for fuse focus bow - Archery
My focus does not have 12 volts to fuses 30-50 but does have from51 to 60
The fuse box inside the car is fed by the power distribution bow under the hood. Check the Maxi-fuses under the hood.
Aug 17, 2011 | 2001 Ford Focus
Toshiba 50hdx82 tv touch focus error blue is bowed.
Convergence is dead.Know how to solders.Must replaced the 2 Convergence ICS,and all it resitors.To do it ur self repair buy a convergence kit at Tv repair World.com,Repeairkits.com.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Toshiba 50HDX82 50" Rear Projection...
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Hour glass bowing on the top and bottom of my HCP4752W Samsung
Check the resistors near the ic, and the fuses to the ic's, i bet you will find an open fuse. the fuse will look similar to a resistor without color bands. use a dvm and set it on ohms, with the tv turned off.
Sep 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Have green bow in top right and green shadows all over
your convergence board needs to be replaced..its out.thats why the bow in the pic
Oct 30, 2008 | Hitachi 46F500 46" Rear Projection...
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Out of focus
Most times when the stk's are shorted the 5 amp cp fuse on the power supply opens. Check all of the cp's by the stk's and on the power supply.
Feb 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Hitachi Ultravision 50" projection Tv
This is an indication of convergence issues. There are two ic chips that control this and there is a likely hood of there failure and need to be replaced. there possible other issues with ouput resistors and fuses. At my shop the cost to replace these chips are 200 to 350. not a too difficult repair.
Feb 24, 2008 | Hitachi 46BX01B 46" Rear Projection...
Archery Logo
69 people viewed this question
Top Archery Experts
Andre De Beer
Andre De Beer
Level 1 Expert
Don A
Don A
Are you an Archery Expert? Answer questions, earn points and help others
