Question about Boston Acoustics Audio Players & Recorders
What are the replacement part numbers for the boston acoustics mcs130 subwoofer transistors Q10, Q10b, abd Q11?
Trying hard to replace the fets of a Boston Acoustics MCS130 subwoofer # Q10, Q10b, and Q11, but I can't read the part numbers off of the transistors themselves. They are fets. Any help is much appreciated! Thank you!
    Genius:
  • Boston Acous... Master
  • 1,054 Answers
Is the sub dead? Because this is usually caused by ZD3 being shorted....not the transistors.
Posted on Jan 06, 2014
  • 2 more comments
  • james
    james Mar 10, 2014
    hi steve i have the problem were ZD3 has blown but i cant tell what it was what part do i need thanks
  • Steve K Mar 17, 2014
    ZD3 is a 18v zener diode. also check R9 on the back of the board, if ZD3 shorts, R9 may become open - it is supposed to be 10 ohms.
  • Anthony Lamping
    Anthony Lamping May 24, 2014
    Do you have a Schematic/Part list?
  • Octavio A
    Octavio A Feb 01, 2015
    I also have an MCS130 with the same problem. Will turn on but no sound. Originally problem was a 60Hz humming sound, replaced the main capacitors C04, C05, C06, C07 and the humming is gone, but no sound. To be honest not sure if there was sound while humming was on since I didn’t try is because humming was quite loud. Based on the answer above I should look for ZD03 and/or R9, but can’t find them. Any pointers on where exactly are they ?. @Steve. Do you have the schematics ??. Do you repair these units ?
4 Suggested Answers
lynchms
  • 93 Answers
SOURCE: how do i connect my boston acoustics pv800
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Posted on Jun 12, 2010
SOURCE: I have a Boston MCS130
mine had the same problem until it completely quit. unplug the sub and turn it over, press gently on the speaker cone, does it move freely, or do you hear a sort of scrapping noise? if it moves freely with no noise, its a dif problem than mine. if you do hear the scrapping noise, then theres a short in the voice coil, from what ive read you have to replace the driver (actual speaker part), its basically blown
Posted on Dec 08, 2011
gopakumarg43
  • 74383 Answers
SOURCE: user's manual for boston acoustics tveem25b-01201
Hello
Try these links to get the user manual to your device.
http://www.bostonacoustics.ca/PDFs/tvee_man.pdf
http://www.mccshh.com/pdf/Designer_Month_Mar2012.pdf
Posted on Feb 29, 2012
Fixing an humming subwoofer
Filter capacitors in the amplifier or a broken ground (shield) wire. Check if there is a ground lift switch in your system and try it in both on and lift positions.
Aug 30, 2016 | Boston Acoustics Horizon MCS130 5.1 10in...
My boston hps12 ho subwoofer blows fuse. what could be wrong
Fuses blow when there is an overload. The most likely cause is a short-circuited semi-conductor IE: a transistor or IC etc. If you find one of these devices inside it with a heat sink on it, that will be the most likely cause. Transistors can be tested with an Ohm Meter and in a short circuit fault such as this, it will be like you have put the two test probes together!
Dec 06, 2015 | Boston Acoustics Audio Players & Recorders
Disassemble mcs130 subwoofer
Go in from the sub plate on the back panel.
and then flip over and remote the driver, followed by the corner screws under the feet for the bottom plate
Sep 11, 2014 | Boston Acoustics Audio Players & Recorders
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
I have a Boston MCS130 surround sound system, have had for about 2 yrs. Was woken up during the night with the subwoofer making feedback noise. Had to turn off to keep from making noise. Have checked...
Feb 06, 2011 | Boston Acoustics MCS 130 LCR Main / Stereo...
I have a Boston Acoustics PV1000 that's getting no power but the fuse appears to be OK. What else could it be? thanks
I have the same problem. La Mars covers the factory repair for these. Their number is 712-546-1644. Have you fixed your problem yet ?
Mark
Nov 26, 2010 | Boston Acoustics PV1000 Subwoofer
561 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
