posted by brum00 on Oct 19, 2007
have clear misfeed (A) on display screen, but no paper is jammed
or in the path anywhere...is there a sensor that needs cleaning ??
have opened all the doors suggested but error still remains...
Best Solution
posted on Dec 01, 2007
There is a thin black plastic armature with a tiny flag on the end of it. that flag movement trips a switch everytime a copy passes over it. If this arm is not seated right, then the flag is not dropping between the switch and which is why the jam lite is staying on. if you open the right sided acess jam door and look straight in, down in the lower right corner you should see this small black box shaped switch, it has 2 thin white wires connected to it By removing the paper tray, you can reach in and try cleaning it with canned air if its not the arm and flag hung up, dust in it is causing the problem.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Ricoh Aficio 1013F Copier
Email this problem
Email this problem
Can you Help with these Copiers problems?
Konica 1216 copier makes black...
I bought a preowned copier... Answer This...
Repair Service
Find Copier Repairman Near You:
