Question about JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV with XinemaSound 3D and QWERTY Remote
Connection loss - JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV with XinemaSound 3D and QWERTY Remote
  • JVC Master
  • 9,742 Answers
Watch what else is going on in the house when the connection is lost. Microwave ovens and cordless phones will disrupt the connection . How far is the router from the TV? You might try elevating the router if it's neat the floor. The higher off the ground the router is the farther the signals will go. Yo may need to upgrade the speed of your service if it isn't the highest speed available.
Posted on Jan 06, 2014
Intermittent power steering loss, and engine power loss
Check battery connections and charging system.
Jan 31, 2014 | Cars & Trucks
JVC car radio KD-S743R/KD-S741R fitted to astra van program memory loss when switched off
One of the wires connected to a car radio provides constant 12V power to the memory even when the radio is turned off. There may be a miswire or broken connection that causes the memory loss
Aug 21, 2013 | Car Audio & Video
As66u wifi connection loss
Many thing interfere with a signal, even the iPad's antenna, which is a known problem, see: http://osxdaily.com/2012/03/21/fix-new-ipad-3-wi-fi-reception-problems/.
Mar 19, 2013 | NA Asus RT-AC66U Wireless AC1750...
1 phase , 50 Hz, 20 KVA , 2200/220 v , is connected as an auto transformer of step up type . Determine , a. The auto-transformer transformation ratio . b. Auto-transformer primary and secondary currents...
This is NOT a forum for college problem solutions. How would you have a 20 KVA transformer and an Atlas Sound AF140... these are different animals... Autotransformer is a more efficient connection when it is possible... the transformer will step the 220 up to 2200+220 volts ignoring the copper loss voltage. For proper designed transformers the primary and secondary copper losses should be close to equal... but in autotransformer connection the efficiency is improved as the added voltage of the supply going to the high voltage winding power does NOT suffer and add to the current required in the primary of this connection. The purpose of this problem is for you to discover that the efficiency of autoformer connection is higher than of a simple step up connection. Now with this carefully work the problem... The ratio I have all but given you... It is unclear what is considered full load here so I would base it on regular connection at 20 KVA at 2200 volts to calculate what the currents would be primary and secondary.in normal connection... calculate resistance of primary and secondary ASSUMING equal losses primary and secondary. What isn't clear is if the loss figures are for the autoformer connection OR just the specs for normal connection. The power factor kink adds to the misery. Approach this problem by making an equivalent circuit of the transformer showing the primary and secondary resistances... again the question is are the loss figures the specs of the transformer or the actual running values for the system....
Sep 11, 2011 | Atlas Sound AF140 140 Watt Autotransformer
Keeps showing loss of connection
do you have the wii fitness board 1 ft. away?
Mar 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
Connected, hi packet loss
check your explorer in the internet options and see your connection settings and check if your connection is using proxy, if proxy change in a default...
Jun 17, 2009 | Computers & Internet
Power loss & all dash lights come on
Check battery connections and alternator connections and starter connections are all clean and tight
Jun 07, 2009 | 2005 Ford Expedition
Power loss on c250 td 1997
have connection on engine management,ty
Feb 23, 2009 | 1997 Mercedes-Benz C-Class
Loss of connection
You're only having problem with the wireless pc right?
Do you know how to access the router setup page?
May 10, 2008 | Belkin (F5D7230-4) Router (587009)
JVC 55 1080p Smart Wi-Fi 3D 120Hz LED HDTV with XinemaSound 3D and QWERTY Remote Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
