Question about LG Home Theatre System HT302SD
Usb not playing on lg dvd
When i insert usb and press play all it says is reading index... help
  • 745 Answers
SOURCE: DVD Writer does not respond when DVD movies are inserted..
Check the box or manual of your DVD writer... See if it support the DVD format of the DVD disk... There are a lot DVD formats nowadays, like DVD, DVD4, HDVD, HDVD-9, etc...
DVD Formats explained
I hate them too, for some DVD works only on a DVD-Player not on computers.
Posted on Jan 17, 2008
shaggyrat
  • 1224 Answers
SOURCE: audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
Posted on May 12, 2008
SOURCE: LG GSA 4082 N
Get a new drive, look around the net... these things are garbage. Mine has the opposite problem of yours. Recognizes everything but DVDs.
Posted on Aug 28, 2008
  • 4 Answers
SOURCE: LG RH299H HDD/DVD does not read purchased DVD's
To unlock the region limitation of your machine:
(all the following is done on the remote)
Press <Home>
Go to the Easy Setup Menu
Go to <Setup>
"Hover" the cursor block over the Lock symbol (don't enter yet)
Enter 0000 on the remote
A Congratulations message comes up.
Press <Enter>
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: my lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Drivers related to hl dt st dvd ram gsa h55n
Posted on Feb 13, 2009
I have an LG FB126 DVD system that only plays region 4. What are the unlock codes to play region 1 and how do I do it??
I was made to understand that there are several versions of this model. Pls try:
  • Turn on your DVD player - with no disc inside;
  • Press pause followed by 3 1 4 1 5 9;
  • screen will display current region
  • Press 0
  • enter
or
  • Press On
  • "No disc" will appear
  • Eject Tray
  • Press '0' more than five times.
  • Press Pause
  • Press Off
or
  • Press "pause"
  • Press "1 4 7 2"
  • edit the 5th number group in the code
  • the first number is the region code
  • example; if the number is "12" then the region is set to 1
  • another example, if the number is "42" then the region is set to 4
  • so if you want all regions set it to "02"
  • when finished press "pause" again to exit from the menu
  • power off the unit and turn back on again.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Televison & Video
MY LG DVD PLAYER HAS A USB ON IT IS THIS USED FOR INTERNET USE I DON'T HAVE CORRECT MODEL NUMBER
The USB port is for external device like usb hard disk, flash drive, incase you have a music or video in them and you dont want to use the disc to play them. immediately you insert the usb device, it will read all the multimedia files on it and it will start play immediately depending on what you arrange in it.
Feb 16, 2011 | Computers & Internet
My lg bd50 is able to play any normal dvds however it is unable to play any bluyray dvds!!! when a blueray is loaded into the machine you cannot even eject the disc for sometime. i downloaded updates to...
hi,
blue ray players takes one to two minute to read the content. it will not read as fater as dvd. give some time and then find out what the player says. error or no disc. also check ur BD's region and the region of the disc u inserted. BD's comes with only one region.
ok
Dec 17, 2010 | LG BD350 Blu-Ray Player
I can't get Terminator Salvation Blue ray to play on my LG BD370
Its a known issue. There is a firmware update available from the LG website. Download the file LG_BD_370M_UPG_LG_V7154.zip and follow the instruction from the website. It solved the issue for me.
Nov 30, 2009 | LG BD370 BLU RAY PLAYER
My LG DV492H will not play DIVX files. Will play audio files vie the usb input but not video files. Believe it may be a setting but have tried various options with no luck. Please advise on what settings...
I have he same problem, as well as my friend. If you insert a DVD video disk, start up the DVD player. It then starts to play the DVD. Stop it and insert the USB drive. Use title to browse to your movies. It then plays them. Tried this on 2 dv492h players and it works
Jul 11, 2009 | Televison & Video
Dvd drive will read/play dvds but will not recognize a cd
go to safemode and try reading CDs in safemode. If your burner still can't read CDs then it's most likely bad. You could get an external usb burner.
Mar 18, 2009 | HP Pavilion dv4000 Notebook
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
Press <Home>
Go to <Setup>
Press <Enter>
Nov 18, 2008 | LG RH299 DVD Recorder/VCR
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
LG Home Theatre System HT302SD Logo
15 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
