Question about Microwave Ovens
Is it possible to mute beeper on older model ge microwave jkp77wop3wg?
Microwave and oven in wall as one unit. Want to stop the beeping.
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: The F3 code keeps coming on with a beeping sound
F3 means you have a shorted membrane keypad.
If it's under warranty, you should be able to get it fixed free.
The "C" in the model number means it's made for the Canadian market, and contacting GE Canada seems to be impossible for us here in the States.
So you'll need to contact GE via the info in your owner's manual.
If it's out of warranty, it's best to replace it, GE does not make parts available for JES-series microwaves.
One assumes they're meant to be thrown away when they fail out warranty.
Please don't kill the messenger... :)
Posted on Apr 28, 2010
espressonist
  • 1711 Answers
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Posted on Nov 04, 2010
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
Beeper wont shut off
Remove the power plug and Allow the voltage present on the board to drain OFF. After an hour please recheck and if the beep still stays there is fault in the motherboard. Possible that the beeper driver is short and is continuous. If all the other functions are working without any issues, all you can do is to cut off the beeper connection if you are able to remove the board and snip off . Attempt with power plug removed .
Nov 06, 2011 | GE JVM1850 1000 Watts Microwave Oven
The beeping sound when something is done can not be heard. Anything I can do to fix?
Does your microwave have a keypad labeled Beeper Volume? If it does, try changing the level by pressing the button and then pressing 1-5 (0 is mute, 5 is the loudest).
If the button is not present or changing the audio level to 5 doesn't help, the problem is the speaker or the wiring for it. I believe the speaker is on the control panel and is not sold separately. Go to https://www.geapplianceparts.com/GEApplianceParts/Dispatcher and enter the model number. This will give you the parts diagrams and price lists.
Most GE appliance manuals are available from GE: http://www.geappliances.com/service_and_support/literature/ and enter the model and click Submit.
I hope this helps.
Jun 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The beeper will not shut off on my advantium 120 m/w
Is there a code "F3" in the display too?
That would mean the key panel (part number WB27X10467 key PCB assembly) is shorted.
The service manual is here if you or someone you know want to check it out and possibly do the work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Jan 29, 2010 | GE Advantium SCA2001BSS Microwave Oven
Would like to mute G E spacemaker microwave ZEM200SF04
Some GE models have this feature, which is covered in the owner's manual.
You can download GE owner's manuals and installation instructions here.
Otherwise, there are three options:
- desolder the piezoelectric element (beeper)
- cut one of both of its leads
- snap it out of the circuit board
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The beeps have become inaudible.
The beeper sound level can be adjusted. Press the BEEPER VOLUME button, then choose 0–3 for mute, medium or loud.
If that doesn't work, unplug the oven a few minutes, plug it back in, then try again.
If you don't have your owner's manual you can find and download one here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JVM1651 Microwave Oven
Microwave JVM1630
From what you have described, it appears that the microwave oven works fine, except that the beeper doesn't work like it used to.
This could be caused by a couple of things.
First, there is typically a piezo electric speaker that creates the "beeping" sound. It's possible that this part has failed. It's a mechanical device and can break. This part is relatively inexpensive.
The piezo speaker is controlled by the microprocessor board. It's possible that there is a problem with one of the output lines from the microprocessor that is tied to the speaker.
One way to determine which part is defective, is to try connecting another speaker in parallel across the original speaker, or remove the original and try the replacement (least expensive method).
If there still is no sound, then I would suspect the problem is on the microprocessor board. (most expensive method).
If I can be of further assistance to you, please let me know.
Good Luck!
- Jim
Feb 08, 2008 | GE JVM1630 Microwave Oven
Beep
This answer assumes yours is a Hotpoint RVM1435, as posted.
If not, please reply back with your correct brand and model.
Model RVM1435 does not have a feature to turn off the beeper.
You can download Hotpoint and GE owner's manuals here:
Dec 07, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
