Question about Walgreens High Output Dual Tank Ultrasonic Quiet Cool Mist Humidifier
One of the tanks cracked - can I buy a replacement tank?
Honeywell humidifier htt-145 leaking from bottom
If you can locate a crack in the clear plastic tank, there may be a chemical you can buy to "weld" the crack closed. If you aren't sure what plastic it is, you might try sealing the crack with bathroom caulk that is mold resistant. You must locate the source of the leak and patch that.
Mar 08, 2014 | Honeywell QuietCare HCM-630 Humidifier
Won't blow mist out
I have a similar problem. I found a crack in the tank. I am trying to find out if it is cheaper to replace the tank, or just buy another one. I have tried other types and like this one the best.
Dec 22, 2012 | Walgreens Cool Mist Humidifier, 1 ea
Looking for a replacement tank for a Sunbeam SCM630 tower Humidifier
This is totally bad product from sunbeam maybe they need to find better quality stuff I have only had mine for one month and went to fill the tank and it has a big crack in it. It was never there before so sunbeam I will not buy your products again they are cheaply made
Jan 22, 2012 | Sunbeam Humidifiers
My wife dropped the the tank on my daughter's humidifier, can i buy a replacement tank?
Yes, go to the crane website. My fan is broken, and if I can't fix it, you can have my tank.
Apr 30, 2010 | Crane Elephant 1 Gallon Humidifier
I dropped the tank. Whre can I get a new tank?
you can check any hardware store or if you live in canada you can check with canadian tire.
May 29, 2009 | Bionaire BCM7204-U 3 Gallon Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
Need to find a new water tank
Mine also cracked along the seam several years ago. I sealed the crack using two-part waterproof plastic epoxy (found at any hardware store.) Not really pretty to look at, but it hasn't leaked since!
Dec 01, 2008 | Holmes Products Cool Mist HM3500...
LEAKS
Try to just fill the tank with water and set it upright on a table. If it leaks, the tank is cracked and needs to be replaced. Order one at kaz.com (search using model#). I have had this tank leak if the special cap is not sitting properly on the base. Make sure that the steam tower is properly locked in place before you place the water tank in the reservoir. The cap on the tank has a spring release that has to be correctly lined up so it only releases water when the water level in the reservoir drops.
May 08, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Walgreens High Output Dual Tank Ultrasonic Quiet Cool Mist Humidifier Logo
Top Walgreens Humidifiers Experts
Rich Brown
ray gallant
Paul Carew
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
