Question about Activision Call of Duty 2 for Windows
Call of duty won't install on windows 8.1 - Activision Call of Duty 2 for Windows
Hi there, somebody install windows 8 pro and is not working properly. I want to restore my PC to windows 8, but its asking me to insert recovery media and I don't know what it is
You can download an ISO of your original OS from Microsoft and using your COA install it as a new install. Don't forget to install ALL drivers from the Samsung web site or it won;t work properly.
Feb 18, 2015 | Samsung 300E5C
Dazzle dvc 10 does it work with window 8 8.1
What software are you using with this device as Pinnacle studio 16 won't launch with Windows 8 8.1
see link below for patch that might fix problem
http://corel.force.com/pinnacle/articles/en_US/Master_Article/Pinnacle-Studio-16-won-t-launch-after-the-Windows-8-1-is-installed?lang=en_US&productTopCategory=Pinnacle_Products&source=kba
It could be a device driver issue but I have not found a windows 8 driver for a DVC-10
Jun 23, 2014 | Microsoft Computers & Internet
Lenovo k430 won't boot windows 7
might due to harddisk partition and format.
you need to use other utility software to format then only install.
But your recovery parttition will gone.
Never able to restore back to win8
Mar 02, 2013 | Lenovo K430 31092JU Desktop PC Windows 7...
My dewalt drill won't switch to hammer
I had the same problem. You need to manipulate either the speed or the torgue. In some cases both. Sometimes the drill/hammer feature gets stuck in between the two an this is the only way to fix it unless taking it apart but I wouldn't do that yourself. Best to take it back to the dealer or service shop
Feb 28, 2013 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
Looking for Toshiba l655 startup disk. Also,i had windows 7, and a friend tried to put windows 8 on it, and i guesses it wasn't the complete program, and now it won't go past the windows 8 startup...
You are going to be forced to rebuild all of the software on your laptop, I did a complete install of windows 8 and hate it....
I have to format my drive and start over.
Good Luck
Feb 13, 2013 | Computers & Internet
Aspire 5532 won't load windows 8
Hello you can test here:
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8
If the pc is compatible to run windows 8.
If it fails, the pc is not capeable to run windows 8.
Here is no drivers for windows 8, at the support site:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=1290
The solution is to continue useing windows 7, or buy a new pc with windows 8 installed.
Good luck
Feb 09, 2013 | Acer Aspire 5532-5535 AMD Motherboard...
AGPTEK sc9-5870 thermal printer won't print
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
Good printer don't give up on it.
Feb 07, 2013 | Brainydeal Agptek High-speed 58mm Pos...
Hp scanjet4850 won't install on windows 7
This fix below will work for Windows 7 and Windows 8 and 8.1 guaranteed, the original software was for Windows XP only. HP have the necessary drivers and Vuescan is a third party scanner program, that is every bit as good as the OEM software, in fact I think it is better.
(1) Download and Install HP Scanjet 4850 Driver: setup_basic_4800_14-5.exe from http://www.hp-drivers-download.com/download/hp/setup_basic_4800_14-5.exe.html
(2) Download and Install Vuescan 64 bit: download from http://download.cnet.com/VueScan-64-bit/3000-12511_4-75328364.html
Sep 19, 2012 | HP Scanjet 4850
I just bougth the call of duty 4 cd, but I have wi...
you have to install higher version of os for the newly game. Install vista or windows 7 now if your computer has enough capability.
May 20, 2010 | Computers & Internet
2004 Mercury Monterey left frnt window sector gear R&R proceedure
are you a techie? You need a heavy duty riveter to do this repair. May have to rent or borrow from auto store.
here's the procedure
Front Door Trim Panel s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (251 KB) NOTE: LH side is shown. RH side is similar.
  1. Remove the parts in the order indicated in the following illustration and table.
  2. Item Part Number Description 1 23942/23943 Mirror access panel 2 1722897 Cup assembly 3 W56904-S424 Window regulator control switch panel screws 4 14A665 Window regulator control switch panel
    Removal Note 5 W701930-S424 Front door trim panel screw 6 W701930-S424 Front door trim panel screw 7 N602703-S61 Front door trim panel screw 8 1723943 Front door trim panel 9 W705590-S300 Nut insert(s)
  1. To install, reverse the removal procedure.
Item 4: Window Regulator Control Switch Panel Removal Note
  1. If equipped, disconnect the electrical connector(s).
Door Window Glass — Front s4w~us~en~file=adobe.gif~gen~ref.gif Printable View (328 KB)
Special Tool(s) s4w~us~en~file=st1132a.gif~gen~ref.gif Heavy Duty Riveter
501-D011 (D80L-23200-A)
  1. Remove the front door trim panel. For additional information, refer to Section 501-01 .
  1. Position the watershield aside.
    To remove individual parts, only carry out the listed steps: Part Steps Front door window glass 1, 3 Front door window regulator 1-5 Front door glass run 1, 3, 6-8
Item Part Number Description 1 W706495-5100 Rivet (2 required)
Removal Note
Installation Note 2 N8621986 Nut (3 required) 3 21410 Front door window glass 4 W706495-5100 Rivet (4 required)
Removal Note
Installation Note 5 23200 Front door window regulator
Removal Note 6 N800507-S Bolt (2 required) 7 21596 Front door glass run 8 — Front door glass run (Part of 21596)
Item 1: Rivet Removal Note
  1. Connect the window control switch.
  1. Connect the battery.
  1. Position the door window glass halfway down to gain access to the door window glass rivets.
    • Remove the rivets.
9391398.gif Item 4: Rivet Removal Removal Note
  1. Remove the rivets.
Item 5: Front Door Window Regulator Removal Note
  1. Disconnect the electrical connector.
  1. s4w~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Prior to power window motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind. Failure to place the regulator arms in a fixed position can cause the spring to suddenly release resulting in personal injury.
    NOTE: The counterbalance spring assists the window in the upward direction.
    Remove the bolts and the window regulator motor.
Item 4: Rivet Installation Note
  1. Using the special tool, install the rivets.
Feb 21, 2009 | 2004 Ford Freestar
Activision Call of Duty 2 for Windows Logo
116 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
Rick Moore
Rick Moore
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
