Question about Dryers
Airworks digital baseboard heater
Unit won't turn ON. Power light and digital screen is OFF but pedal power lights up
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
Posted on May 13, 2007
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
advacak
  • 125 Answers
SOURCE: electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Posted on Dec 31, 2008
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
The heater is causing interference with my Satellite TV signal reception. When I turn on the heater my signal begins ti digitize then it goes out. what can I do to prevent this I have the baseboard heater...
sounds like the heater might have a bad heating element or the transformer inside the unit is shorting out. first thing that I would check is to remove the wire plate and check for any burned out wires. ( this unit could be a serious fire hazard ) --- you could always have a electrician come out and check the unit for voltage problems or for about the same price you could go down to your local Hardware/appliance store and just buy a new unit and replace it,, they install very easy and it only takes about 30 minutes to remove and replace the unit --- try and get a unit with the same messurments so you will not have to paint the wall area around the new unit.
now one more quick test to trouble shoot the unit --- try and run power to your satellite system via a extention cord and a different outlet from inside the house. there is a chance that the sat system and the baseboard heater are sharing the same power source and when the heater kicks on ( with its problem ) it is causing a issue with the sat system.
again,,, check out and solve this problem soon as it could lead to a electrical fire.
c...
Jan 30, 2011 | Lasko 5620 Electric Baseboard Heater
How to wire unit baseboard heater to the power to thermoster
That is a portable unit and should not be hard-wired and controlled by a wall-mounted thermostat. The unit may never cut off that way.
It is considered a "space heater" not an area heater.
===sorry===
Sep 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
I have one thermostat for 4 electric baseboard heaters all in seperate rooms, i want to disconnect one of them how do I do it?
You have to shut the power off to all your baseboards, make absolutely sure that the power is off !!!!! once you are sure, then its a matter of unscrewing the unit from the wall, then opening up the panel, uncouple the wires inside the unit that supply the power, wire nut the wires then tape with electrical tape, if at all possible remove the power leads from the breaker panel that feeds that particular baseboard, if not, then make extra sure you have the power leads secure and taped off as so they will not touch together or anything else, I would strongly recommend that you hire a certified electrician to do this !! as this type of home repair is very dangerous and deadly. hope that was helpful
Jan 17, 2009 | Fahrenheat Electric Convector Baseboard...
Electric hydronic liquid-filled baseboard heaters
The same comparisons with other forms of electric heat (i.e., radiant, electric strip baseboard, etc.) are the same. The difference is cycle time - the liquid-filled electric heaters turn on and off less frequently than strip-type to maintain thermostat temperatures. This also means that the unit's temperature will swing more widely than the desired average thermostat setting (the liquid's temperature will signal the thermostat to turn off power, but the temperature will continue to climb; similarly the liquid will signal the thermostat that it is cool enough to engage power but the liquid will continue to cool after power is engaged - similar temp swings with hygronic heating systems). Some say that the liquid-filled units are safer, but the manufacturer's installation guidance is usually the same between strip and liquid-filled so both pose an equal safety hazard.
Sep 21, 2008 | Fahrenheat PLF1504 Baseboard Heater
Worn out baseboard electric heaters
The only safe way is to read the voltage with a AC voltmeter. Turning off the power to that heater connecting the test leads and turning the power back on. There is only two leads going to the heater and you should always dissconect the power befor connecting the test keads. Your meter shoud be set to read the highest of the two voltages.110 Volts or 220 Volts. You might get lucky and find a name plate on the unit with the voltage shown.
Feb 22, 2008 | Heating & Cooling
Wiring on thermostat tl7235a1003
OK, here's my guess at this...I hope someone more knowledgable will confirm or correct me.
A line voltage thermostat switches the power to the baseboard heater. In other words, it's just like a wall light switch except it activates and deactivates based on the temperature.
I think your old model CT62 was wired exactly like a light switch. The hot wire to the light is broken then run to the wall switch and then back to the light so there's no neutral wire at a light switch box. This worked fine for your CT62 because it did not need power, it only needed to switch it.
The new model TL7235A1003 requires electrical power because it's programmable so you need both a hot wire and neutral wire at it's installed location. In addition you also need 2 wires leading to the baseboard heater so the thermostat can supply it's power.
I believe L1-L2 are to be connected to the hot/neutral wires, and the Load wires go to the baseboard heater.
If I am correct you will not be able to use this thermostat without some re-wiring.
Good luck.
Nov 27, 2007 | Ingram GMS90904CXA Heater
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
