Question about Sony PS-LX250H Turntable
Turntable will not turn
Arm raised up and down, but when I press start the turntable does not turn
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
I have the same problem with one I just got, wont do anything, no power. I have the P-320 it's a nice turntable if it would work.
Posted on Jul 21, 2014
Turntable arm will not lower - the guide just pushes it back to the off position
Try to do this
1. unplug the turntable
2. raise the arm
3. put it over the record
4. lower it which will not lower you said
5. push the arm to the very end close to the label
6. rotate the turntable by hand and it should take it through the whole return cycle of the arm and lower and finish the motion
7. then plug in and it should come back to normal
Dec 26, 2016 | Audio Players & Recorders
How do I turn a technics Quartz SlQ200 on
Assuming it does not need repair, you should be able to slide cueing lever to the right (raising arm), then place over the record and the platter should start turning. Just slide cueing to left and needle should gently drop on the record. Just press stop button to return the arm and platter should stop/turn off.
Oct 08, 2014 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
I have an Aiwa PX-E80K turntable. Whenever I start the turntable, the tonearm raises moves across, drops on the outer edge of the vinyl then then turntable stops. The belt is still attached. Anyone able to...
I suspect the belt is that slack that when the arm weight is on the record, the belt slips around the shaft of the motor. Does it start up again when the arm is lifted up? If it does then you need a new belt.
Jan 09, 2011 | Aiwa Audio Players & Recorders
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Lifter moves, but doesn't reach the tonearm
it was probably lifted with the arm locked in the cradle.there is usually a set screw on the side of the arm lifter to adjust the height.it is on the lower half on most,so removing the bottom cover of the turntable is needed.loosen the screw and slide the piston up until it almost touches the arm in the down position.that way when you raise the lever,it will raise the arm. lift up the rubber mat and tape the platter to the side of the unit so it does not turn or fall,if you do not want to remove it .
Oct 23, 2009 | Numark TT200 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
When i turn my turntable on,they is a slight dip and rise in the platter is this normal.if not what should i do to mend it.
Is the platter itself moving up and down or the record? It could just be the record's wear and tear (warped) which raises the tone-arm which in turn makes it move up and down on certain sections of the record. Try bending the record (very very slightly) to straighten it out or put more weight on the tonearm.
Sep 11, 2008 | Numark BATTLE PAK v.4 Turntable
Sony PS-LX250H Turntable Logo
383 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
