Question about Pioneer Audio Players & Recorders
Volume control problem with pioneer axd7531 - Pioneer Audio Players & Recorders
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
Pioneer vsx1021k volume drops by itself at 3db increments until there is no volume. M volume is displayed when this happens as if someone was manually turning the volume knob.
Dirty rotary encoder (volume control ). If you are confident with opening the unit yourself, a spray of contact cleaner into the encoder might help. Ideally u should replace it.
OR
The volume minus button on your remote is dirty/shorted. Try removing remote control batteries and see if the issue disappears.
Aug 14, 2014 | Pioneer Audio Players & Recorders
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Have a load uncontrollable volume with my Pioneer VSX-d409 receiver. A suggestion for a low volume problem was to correct with tuner cleaner (potentiometer ) problem. Can this be corrected by me as perhaps...
Your problem is not with FixYa, but rather the volume control potentiometer on your Pioneer receiver. As for whether you can fix it yourself, that depends upon your ability to disassemble the receiver to gain access to the volume control and make the repair
Jan 16, 2013 | Pioneer VSX-D409
Replacement volume control knob for pioneer deh
an authorized service centre in the back of the pamphlet that came with the reciever,or direct from pioneer.
Jan 13, 2010 | Pioneer DEH-P6900UB CD Player
I need a help to find the nomber part of the volume control
Volume control or rotary encoder part number: ASX7004, located on a small board - rotary encoder assembly: AWX7386
http://futureshop.partsearch.com/Part/Pioneer+Electronics/Pioneer/VSXD409/Pioneer+Electronics/Pioneer/AWX7386/New.aspx
Jul 10, 2009 | Pioneer VSX-D409
Can't find part needed.(Pioneer SX 1250 volume control part # ACV-169. Is there a replacement
Your only recourse at this time is to check with local servicers that may have one around in their old stock. Or check Ebay for a parts machine that you can salvage one from. I believe that the volume control from an SX-850 will be the same, so you can search for one of those as well.
Good luck.
Dan
May 19, 2009 | Pioneer Audio Players & Recorders
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
