User guide for rostra 250-1775 cruise control
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1988 - 1991 Honda Civic...
1988
1989
1990
1991
Constant 12V+: White/Blue
Ground: Black
Dimmer: n/a
Front Speakers:
Left Front (+) Blue/Green
Rear Speakers:
NOTES: - none -
Metra Brand Dash Kit: n/a
Accessory: Blue/White - Ignition Switch Harness
Tach: Blue - Distributor
Trunk Pin: Green/Black - (-) Harness from Dash Indicator
Parking Lights: Red/Black - (+) Fuse Panel
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Red - (-) Driver's Kick Panel
Door Lock: Green/White - (-) Driver's Door at Door Lock Module
Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module
Horn: Blue/Red - Steering Column (Relay Required)
NOTES: - none -
CRUISE CONTROL:
VSS Wire : Yellow/Red - Driver's Side Dash Footwell, 13-pin connector.
NOTES: 4000PPM
on Apr 01, 2010 | Honda Civic Cars & Trucks
What is the rostra precision controls for
This web site can give you some info http://www.rostra.com/manuals/Form4428L.pdf
May 12, 2014 | 1994 Ford Escort
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1984 - 1987 Honda Civic...
1984
1985
1986
1987
Ground: Black
Dimmer: n/a
Front Speakers:
Rear Speakers:
NOTES: - none -
1984, 1985:70-1388
1986, 1987:70-1720
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
1983
Illumination: n/a
Dimmer: n/a
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Rear Speakers 6 1/2" Rear Doors
Left Rear (-) Gray/Black
NOTES: - none -
Metra Brand Wiring Harness: 70-1388
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
I want to install cruise control on my 2003 dodge ram 1500
I doubt that you can. The after market kits are for manual transmissions only. The additional equipment that is required is a stepping motor for the throttle and it wont work on electronic throttles, a new speedometer shaft sensor and the controls. But here is the info: http://www.thecruisecontrolstore.com/2003-2006-dodge-ram-truck-complete-rostra-cruise-control-manual-w-gas-engine/
Feb 10, 2014 | Cars & Trucks
I have a 2006 Scion Xa that tried to kill me today. SERIOUSLY. I had cruise control on and was doing 70. Turned cruise control off as I entered a mid size town and WTF the car wouldn't idle below 60mph. I...
Next time that happens, like the tech said tap the gas peddle, but if your coming to traffic or a town or a stop, slow down as much as you can, throw it in neutral (as if you put it into park while still moving with speed, that could screw your transmission. Anyway, put it into neutral, turn it off, tap the gas peddle like the tech said, and then restart the car. (To be on the safe side, rather then having the car rev growing.
Yes like you said their is a TSB for this and my buddie has experienced the same problem, coincidentally while I was driving with him. What happens is when you tap the break or cruise control, the mechanism that controls the throttle cable fails to let go, so thus when you tap the peddle it kinda nudges it back.
You could say the mechanism that takes control of the throttle, sticks yes.
You do know that the manufacturer will replace this for you free - no charge? So you will have no more problems anymore. Owners can contact Rostra at 910-291-2538.
Oct 20, 2009 | 2006 Scion xA
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
1980
1981
1982
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Tach: Blue - Coil
Hood Pin: n/a
Factory Disarm: n/a
NOTES: - none -
CRUISE CONTROL:
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
