Magnivox 32mf337b/27 Firmware Upgrade - Computers & Internet
My magnivox was hit by lightning. Does it have a relay or something that I can replace to fix it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 16, 2017 | Televison & Video
I have a Magnavox 32MF337B/27 the tv turn's on 2 sec later it turn's off.
Check inside for Bulging electrolytic capacitors and replace them. Samsung was famous for it.
Feb 03, 2013 | Televison & Video
Am I diagnosing the problem correctly?
Sounds like a bad component in the power supply. Most likely a bad capacitor.
Nov 16, 2011 | Televison & Video
I downloaded lastest firmware v1.15 for my Philips 42PFL3603D/27 LCD TV. Unzipped it and put it on an empty 8GB jump drive then plugged it into the TV. I unhooked everything to the TV, turned it off,...
when you unzip the file you may need to put it into a file called "upgrades". Try an empty USB stick (size should not matter) and put the autorun file into the upgrades file.
Feb 11, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
1 Magnavox 32" LCD HDTV MAG 32MF337B
Replace your capasitors on the power circuit board.. They are junk to begin with.. They are cheap.. Thats all i can suggest..
Nov 26, 2010 | Televison & Video
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Dec 03, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Firmware upgrade and lost all channels
How are you getting your channels,cable,dish,air? Your best bet is to go in and rescan your channels.
Nov 01, 2009 | Syntax OleviaL 527V 27 in. LCD Television
HDD6330 freezes with USB
Revert back to Windows Media Player 10, and don't use Vista - these are the minimum requirements for not messing up this player.
Reset the player, do Repair in the Philips Device Manager, and do the firmware upgrade firmware upgrade. There is nothing else you can do really. Reformatting generally doesn't help with this model.
www.usasupport.philips.com for more details
Jun 22, 2008 | Philips GoGear HDD6330 MP3 Player
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
