SOURCE: cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
SOURCE: Game Cube - Sound perfect, but no image
http://www.yamaha.co.jp/manual/english/result.php?div_code=av
Try this site for your HTR-6130 user guide. Hope this helps.
SOURCE: I recently hooked up my vizio soundbar to the
hi ,
check the is there is any short inside the RCA connector. if so this problem can occur.
also if the center amplifier stage have any problem it will get shut down. may be the output transistor of ur center amplifier get damaged. check the same
ok
SOURCE: i just bought a soundbar
hi, i have exactly the same problem, even muting tv sound does not work. I have sent a few minutes ago a question to LG customer service and startednow waiting...
SOURCE: how do i connect a soundbar to this receiver? My
Hi there, use your pre-outs, you shuld have pre-outs for all channels, I think the soundbar is supposed to create its own surround effect so I would connect it to the front two channels
