Question about Motorola Radio Communications
Sp 50 It's just beeps when I press button. Both of them do it when on same channek
    Problem Solver:
  • 6 Answers
That usually means that channel isn't programmed to transmit, it is set to receive only. Or even more likely the battery is weak and can't supply the amp or two it takes to transmit. Make sure you know what is in the radio and the condition of your battery. The SP50 is a professional grade radio and shouldn't be operated unless you know what the channels are.
Posted on Jan 04, 2014
How do i turn off the hourly beep on my timex ironman t5k160?
press and hold the upper left button which is set, the seconds blinks then press the mode button/the lower left button until it reaches the chime turn it off pressing the middle button once. if your done press the "set" or upper left button. i hope i had been helped you.
Aug 10, 2011 | Timex IRONMAN Triathlon 50-Lap Mid T5K160...
How do I change the Name of the person at an extension on the Panasonic KX T7431
press the Program Button, then (**1234), and scroll counter-clockwise through the options with the volume circle. the option should say, "004 ext name set." to enter into that option to change, press the sp-phone button. continue pressing the sp-phone button until you find the extension number you would like to change. once you find it, press the transfer button and spell the designated name using the dial pad. For example, Mike (press 6 and use the volume circle to browse the letter you need from that assigned key- to get M) to continue spelling the name, continue using the dial pad and repeat to assign the designated letter. to store the name, press the "Auto Dial/Store" button and it will beep to confirm.
hope this helps, deanna
Jun 28, 2010 | Panasonic KX-T7431 Corded Phone
Can i set the f50 to beep after each mile i run?
Yes. When in Train mode, press and hold start/stop to enter the settings mode and press the View button until "Auto" appears to turn on AutoLap, then set the distance to 1.00. your watch will beep at every mile and automatically record each mile split for you. ... its one of my favorite features!
Sep 30, 2009 | Garmin Forerunner 50
It is beeping "Error" with 5 beeps
5 beep error means that the waste ink tank is full. You can reset the counter to make it print by doing the following: You have to be exact. If you make a mistake in any of it, just go back to the beginning and start it all over.
1.Unplug the power cord from the printer
2.Hold down BOTH the POWER and RESUME button at the same time and then plug the power cord back in. Keep holding down the buttons until the printer finishes its powering up noises.
3.After the printer is quiet, release the POWER and RESUME buttons. Then hold down the RESUME and CARTRIDGE buttons at the same time with one hand, and press the POWER button with the other. KEEP HOLDING DOWN the RESUME and CARTRIDGE buttons until you hear 2 beeps. They will come quickly together and one beep will be longer than the other. Listen carefully, as they are not very loud.
4. Once you hear the 2 beeps, release both buttons.
5. After both buttons have been released, then press the CARTRIDGE button 15 times. You will hear a beep each time it's pressed.
6. After you finish pressing the cartridge button 15 times, then press the RESUME button one time. The printer will beep and shut off.
7. Turn the printer back on by pressing the POWER button. The printer will work fine now. The waste ink will have been reset to 50% full.
Sep 29, 2009 | Canon BJC-85 InkJet Printer
Error and power light blinking.
Here is the Waste Tank Full reset.
Canon BJC-50 BJC-55 BJC-80 BJC-85 M40 M70
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Mar 30, 2009 | Canon BJC-85 InkJet Printer
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Getting my digital watch to stop beeping every hour
i think the battery is low voltage,try to change the battery 1
Aug 25, 2008 | Timex Sports Ironman Triathlon 50-Lap...
KX-T7730
open the system programming(its the phone connected to jack 01) press program button and enter * and # followed by the password(1234), then enter 104, press 'SP-PHONE' then auto/ans button to select, select external music, press store button.
SORRY I FORGOT THE SP-PHONE BUTTON, Dont worry about the display "101" just press # it will change to date and time.
Jul 28, 2008 | Panasonic KX-T7730 Corded Phone
Timex expedition indiglo wr 50m
I had the same problem, and could not find any answers on timex.com. After you place the battery in and it begins to beep, push all four buttons in at the same time. This should "reset" the watch -- at least it did for me.
Mar 24, 2008 | Timex Expedition 40141 Wristwatch
Radio Communications Logo
50 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
