Question about Samsung Televison & Video
Tv picture shaking - Samsung Televison & Video
What causes my picture shake
Check your TV level ... it must stand on a firm foundation ... it wobbles because your floor shakes - reduce the shaking by improving its contact with the floor.
Jan 15, 2013 | Hitachi 60UX58B 60" Rear Projection...
Picture shakes
sounds like caps dying on power board
Nov 28, 2012 | Samsung UN55B6000 54.6 in. LCD HDTV
Hi i Have a Toshiba 50H82 all the colors is good but the picture is really blur and shake, does someone knows of to fix it, im not shure if its call the tuner of the tv....
If the video is shaking, zig zag looking, etc your hypermodule has failed. This is common on your model. Some peeople call it hyper board, hyper module, etc..all the same.
You can get a repair kit for this from www.TvRepairKits.com
Oct 19, 2010 | Toshiba 50H82 50" Rear Projection...
TV picture is shaking up and down.
Try unplugging any devices near the TV one by one and see if that helps.
I had the same problem with my picture shaking on all HD channels and found that it was my land line phone interfering with the signal.
Hope that helps!
Dec 11, 2009 | Samsung LN46B640 LCD TV
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
Shaking of pictures on tv
a flux could cause bulb lead to come out of flux this is one thing that makes it shake
fan blade on cooling fan broke maken it shake
uneven service thats not solid can make it shake
Apr 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Admiral tv picture
A shaking picture is probably bad solder joints on the PCB.
Reflowing any dried or cracked joints with some new solder may solve the problem. As for a service manual, if one is available we would need to know the model number of the set to find one for you.
Mar 12, 2008 | Televison & Video
Picture Shaking
Do you have any big speakers or some other appliance near the TV?
Magnetic fields make the screen images 'shake'.
Dec 09, 2007 | Sony FD Trinitron WEGA KV-36HS20 36" TV
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
51 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
