Question about LG 42LC2D 42 in. LCD HDTV
TV TURNS IT SELF OFF AND ON I HAVE A LG 42'' MODEL 42PC3DV
I had the same problem with it turning on/off constantly, also it "popped" loudly when I would change channels at times. Now I have a 4 amp fuse blown that seems to keep my bulbs from lighting.. What is the part # on the start relay, and where do I get one.
  • 3 more comments
  • radiorick234 May 22, 2009
    First my television is an LG plasma, model 42PC3D. I can take care of the fuse issue very easily. I NEED TO KNOW THE PART # OF THE START RELAY, ITS COST, HOW TO GO ABOUT PURCHASING AND INSTALLING IT. My problem again is the tv would be difficult in turning on, turning itself on/off without command, turn itself on/off when changing channels, pops alot. Now the 4A fuse is blown and I just have sound, and no picture. Looking for real help, not someone telling me about e-bay or warranties.
    LOOKING FOR START RELAY INFO.
    I have replaced the 4 amp fuse, and tried to power up the set. I now get 4 blinks of the green light, it then goes back to solid red. Nothing seems to happen to the picture. re-checking the fuse, it test good. No sound at all from the relay. Is it poss. the relay has totally burned open? seem to be going backwards.
  • radiorick234 May 26, 2009
    Still looking for help with my LG plasma tv, model 42pc3d. Original problem the tv kept popping, turning itself on/off. Finally, the 4a fuse has blown, with the fuse out the set has sound, but no picture. Putting the fuse back in the green light blinks 5 times, but will not give sound or pic. Someone has told me to replace the start relay. I need to contact someone that can help me.
    Rick Rankin 618 978-4071
    this is a plasma tv, LG 42PC3D. Are we talking about the same problem?
Ballast? Lamp? Inverter....? Why would a plasma tv have these parts?
wondering...
RGB
Posted on Jul 12, 2010
  • 744 Answers
Hi..It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Posted on May 26, 2009
  • Prakash Ram
    Prakash Ram May 26, 2009
    hi,
    the ballast are bad. replace this and you will be OK. Ballast Lamp does not have any filament inside like ordinary house lamp.DLP TV Lamp drives through approx 1K volts produced by ballast supply to generate light by spark between electrodes of lamp.
    I hope you got original lamp as replacement and it is not aftermarket or compatible lamp.
  • Prakash Ram
    yes same problem
  • 749 Answers
Try a hard reset just unplug it for 30mins and try again
Posted on May 22, 2009
  • 355 Answers
I think their is blown fuse on ZSUS terminal board and replaced it.....also check for blown fuses on the rest of the boards as well, if there's a blown fuse on any of the bds the power supply will turn itself off if it doesn't sense a load. hope this helps.
    Sergeant:
    Champion:
  • 219 Answers
you need to replace it.I think it is 4AH250V. You can buy it from any electronics shop near u or u can get it from ebay.com
Thanks!
Sandy
  • Sandeep Gupta May 22, 2009
    hi well if its under warranty LG will replace it for free
I have a LG 42pc3dv with no picture just sound. I have this tv over 3 years, other people experienced the same problem, some of them mentioned the Y sustain board. Is this an easy fix.
Check the fuse on the Z-sustain module. The module all the way to the right (looking from the back) If blown (and before the set went out there was a loud pop) you need to change the IC on the Z-sustain part number STK 795-820 or 821 and the fuse. If you don't want to bother unsoldering and soldering back this part and you know the fuse is blown then replace the Z-sustain module. Do a google, ebay, or shopjimmy.com search with the model number for price and availibility.
Jun 16, 2011 | LG 42PC3DV 42 in. Plasma EDTV
My LG plasma 42pc3DV-UD just turns off while we're watching it and then turns itself back on again. It does this sporadically, any body got the fix on this?
The tv power supply board have dying parts call the capacitors.These capacitors are dying and have leaking gases.These dying capacitors are alway bulges up on it tops or puffing up on it tops.The power supply board the board that the board,where the power a/c cord plug into it.U have tools like a soldering iron,desoldering pump or desoldering braids,solders?U can do basic soldering?U have basic understanding of electronic?Replaced these dying and leaking gases capacitors,that are bulging up on it tops or puffing up on it tops.This sporadic turn off and on will stop.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 20, 2010 | LG 42PC3DV 42 in. Plasma EDTV
LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
LG Plasma 42pc3d turns on, pops, turns off
Its very likely that you need to have LG perform a sodtware upgrade on your unit. Contact LG and see if your tv is one of the applicable units with software upgrade issues, please let me know if it works. Good Luck.
Dec 02, 2009 | LG 42PC3D 42 in. Plasma Television
I have a lg 42pc3dv plasma tv. it made a loud pop
Looking at it from the back, the board on the left is the ysus. You should see a big red cable coming from the power supply board in the middle of the set going to the ysus. Near the red cable plug on the ysus should be a fuse. Most likely the fuse has blown. If it is you need a ysus PCB. Check out encompassparts.com. If you get a new board be sure to set all the controls on the new board to match the old board. If you don't you will have little sparkles all over the screen when it comes back on. I hope this helps. You may want to check all fuses on the power supply and the zsus which is on the right side of the set. I have seen both the ysus and zsus be bad together. Good luck and thanks.
Oct 24, 2009 | LG 42PC3D 42 in. Plasma Television
Shutting on and off
99 percent of this problem is caused by the main printed circuit board becoming faulty.
Jul 06, 2009 | LG 42LC2D 42 in. LCD HDTV
WON'T TURN ON.
Powerboard damaged, if you could not see the Led light on stanby mode it means you have no power at all.
Go ahead and replace your powerboard and your TV will be Ok
May 28, 2009 | LG 42PC3DV 42 in. Plasma EDTV
You have a bad start relay in the power supply Replace it
May 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv turning on and off by its self
You have a Bad power board, you should get this replaced before the inverter chip get fried
Mar 21, 2009 | LG 42PC3DV 42 in. Plasma EDTV
LG 42LC2D 42 in. LCD HDTV Logo
769 people viewed this question
Computer Repairing
Computer Repairing
