RCA 22LA45RQD LCD TV/DVD Combo Logo
Wayne Conlon Posted on Jan 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wilkl not turn on...completely dead
Is there a fuse in this thing? If so, what does it look like? Already have it opened up
shaun taylor
Level 3:
  • RCA Master 1,527 Answers
  • Posted on Jan 04, 2014
shaun taylor
RCA Master
Level 3:
Answers
1527
Questions
0
Helped
338408
Points
3957
Hi they look like this if you can't see this you may have one like this it's.called wickman fuse you need a multimeter to test them hope it helps
regards
shaun
Wilkl not turn on...completely dead - f818f2d9-2c22-41c8-a50e-44361ddcbc52.jpg
Testimonial: "Neither one of these fuses are on the power board"
  • Wayne Conlon May 11, 2014
    I dont see either one of these fuses on any of the 3 boards
Why doesnt my pontiac g6 turn on it makes no nois eor anything and i checked the battery alternator and starter but not the ignition switch
Not enough information.
Is the car completely dead electrically, or does it do things like:
-interior lights operate when door is open
-dash lights operate when key is turned to 'run'
-starter turns when key is turned to 'start'
If you have no electrical power to anything, I would definitely start checking under the hood first. A voltmeter is the tool that will help you the most here.
-Battery terminals tight, battery not dead, cables (both power and ground) carry current where it belongs (zero ohms). Tight electrical connections everywhere.
- The underhood fuse panel contains nearly all the fuses, fusible links, and relays needed for your engine to run. Checking with a voltmeter is quicker than pulling and visually inspecting components.
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
My magtag over-the-range microwave (Mmv4205baq) is completely dead. It's not very old, can it be repaired?
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Microwave stopped working
The main fuse in the microwave is probably open, causes are! door switch, magnetron, inverter board, "if 7 years old or less" and possibly the keypad control board. I recommend having it checked out.
Power Problem Samsung Exclaim
You can try running the battery completely dead and then recharging, but it sounds as if you have done that already. I would recommend purchasing a new battery as it sounds like it is dead.
Cd navigator
If the unit is completely dead, you may want to check the inline fuse and/or the fuse of the vehicle assigned for accessories/radio.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
It´s dead
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
Hitachi TV will not turn on.
If have already unplugged and waited for atleast 15min. and still no success. Then only if you are Electronicly inclined. Check to see if you get dead completely or you get an indicator light momentarly. Which these are two different symptoms. first dead no indicator. check R931,E994,Q777. Then if indicator light comes on and goes off, check E994 which is fuse opening, C707-1000pf 2kv cap, also check D915, I601, IK04, and 05
Will not power on......what could be the problem on the board?...i am good at soldering things...will replace if I new what to replace
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
