Question about IGG GodsWar Online
Expception Error Error#:0 [0x0] Function: SceneManager::create_entity Description: Create mesh object failed with name obj001656.. File: M:\Easy3DStaticLib_Source\Easy3D\code\graphic\scene\SceneManager.cpp Line:89 thats the error that keeps coming up every time i try to join the game, i can log in, but cant join in. Can someone help me with this?
How can I get the gmail account reinstated?
Why not just create a new account for the purpose you need specifically. You can have as many accounts (email addresses) as you wish. With Yahoo I have some two hundred email addresses. Whenever I have a transaction with a new entity (person or business) I create am email address that has the name of that entity in it.
Feb 14, 2015 | Google Gmail
Activex component can't create object
Do the following tasks:
  • Reinstall Windows Script
  • Repair Windows Script File Information in Registry
  • Reregister Concerning File
  • Reset Internet Explorer Settings
  • Restore your Computer
  • Repair System Files
If you want to fix this error instantly then use a system utility software RegInOut to fix this error.
Hope it works for you.
Dec 22, 2011 | Computers & Internet
I get an error code when trying to complete the install of a new business. The error code reads; Create Company File Error, Exceptions: Save Entity Exception. I have windows xp, and I turned my antivirus...
ok you have to create a file with all the compay details try looking for a set up wizard.
thats the best i can offer as im not 100% oncertain types of software.
Oct 06, 2010 | Avanquest My Invoices And Estimates Deluxe...
Why main function is made static in java
Its very easy dear. In java everything is object oriented. You will call a function through an object. Now we are calling the main method without any object as we do not create any object of the class that contains a main method. So call the main method we need to declare main as static methos so its not a part of an object but a class so that mian method can be called without having creating any object of the class.
Regards, polysandy
Jun 27, 2010 | Sun Java Programming Language (cdj-275)
Failed to Create print object
Step 1: Click Start --> Printer and Faxes --> Add a printer.
moz-screenshot.jpgStep 2: While wizard appear, click next and tick on A network printer or a printer attached to another computer. Click next.
Step 3: On the specify printer options, tick Connect to a printer to the Internet or on a home or office network. Specify your printer destination. Example: http://192.168.110.120/
Jan 30, 2009 | Lexmark X945E Printer
Active directory
An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "dynamicdata.fabrikam.com". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
Java gui code
Okay. I'll try and explain what this code is doing for you.
First thing you need to understand is your "gui" is what is known as "Standard Out" and "Standard In", this is how Java outputs text to the console, and how it inputs text written by a user from the console. A function like "System.out.println([some string])" will print out that line to the console.
Second thing is the idea of classes. A class can be thought of like a code "blueprint". You write the blueprint, and then you create individual "objects" based on that class in your code. While each object is independant, and has it's own properties, functions, and its own spot in memory, it is based on the same code.
If I made a class called, say, "Shape", and I gave it two properties, "Size" and "Color", then I could in my program make lots of different "Shape" objects and they would each have their own independant sizes and colors. Yet, if I made a function in the class called "Draw" which magically drew it on the screen in the appropriate size and color that I had specified, I could call "Draw" for each object, and each shape would be drawn on teh screen. The same code is being executed for each shape, but with different values for the size and color, since each shape object is its own unique entity with its own size and color.
The whole point of classes is so that you don't rewrite code. If you needed to have 1000 shapes on the screen, it would be silly to write the drawing code out 1000 times, one for each shape. It's much easier to write a single blueprint that applies to all shapes.
That said, your code above has a number of "classes" at work.
The "Products" class is a class which stores information about a "Product". In your case, this info looks like it is the name of the product, it's price, how many are in stock etc.
The "Inventory" class is a class who's purpose it is to keep track of an array of products. There are a bunch of functions inside this class. I'll describe what they do below
The buildinventory() function appears to build up a list of products for use in the inventory. Notice how it calls the line:
product[0] = new Product(1, "socket set", 3, 19.99);
filling up the "product" array? Each call there created a new "Product" object which was based on the "Product" class. So each object has it's own name, inventory number, stock, price etc, but they all have the same set of functions to do things like, say, get the price of the product (the getPrice() function), or get the name of the product (the getName() function). It's the same function, as defined in the Product class, but when called on a different product object, it will return different results. This works well for an inventory program.
The "DisplayInventory" function loops through all of the products that the inventory class has created, and outputs information about each one to the screen. By the looks of it it is also keeping track of the total value of the inventory, in a variable called "totalPrice". Every time it loops through a product, it adds the product's price onto the total. The idea is once that while loop has finished, that variable will hold the final "total" of the inventory. After the loop has finished you can do a System.out.println() and use that variable to display the final total. This is probably part of what your project is asking you to do.
The "SortInventoryByName" function simply sorts the list of products that the Inventory class has created based on the name of the product. It does this using a build in Java class that you don't need to worry about.
You'll notice a function that is just called "Inventory()" near the top. This is called the "constructor". When you create a class, the class sometimes has to do a bit of initialization work before it is usable. This function is called as soon as the class is instantiated as an object somewhere in your code. So in this case, when you eventually create an inventory object, that function will be called and the inventory will be built (by calling buildInventory()), sorted (by calling sortInventoryByName()), and displayed (by calling displayInventory()).
So it looks like you have this great Inventory class that does everything you need it to do. So now what? It still doesn't do anything! The reason is because it itself is just a class. It's a BLUEPRINT for an inventory. You need a Java program to USE the inventory class to actually do something useful.
You need to make a java program with a sub main() in it (just like every program you've ever made in this class). And inside there initialize a new inventory object, just like how the inventory object made product objects.
e.g.
Inventory myInventory = new Inventory();
Remember the Inventory() constructor! It will get called here, and the inventory class will go ahead and build an inventory, sort it, and display it on the screen.
So hopefully this will help you to understand your class a bit better. Again, real programmers don't just take classes and use them, they need to understand how they work. It's true that occasionally you can find something that does what you need it to do, and you don't need to "Reinvent" the wheel, but if you are unable to understand what it is doing, you can never modify it or tweak it, and if your problem isn't perfectly solved using the class, the class is useless to you. Programmers write their own modules and re-use them as they see fit, and occasionally they use someone else's code as a template. This is why you are learning how to modify an existing class.
Jan 26, 2008 | Computers & Internet
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Button script
how to link 1 frame to 6 frame with button give me script
Dec 01, 2007 | Macromedia Flash MX
Video Game Consoles & Games Logo
27 people viewed this question
Top IGG Video Game Consoles & Games Experts
James Wishart
Are you an IGG Video Game Console and Game Expert? Answer questions, earn points and help others
