Question about Maytag Washing Machines
Beaumark washer how to replace a LID SWITCH
ghappliances
  • 126 Answers
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 1122 Answers
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Posted on Oct 26, 2008
scottowa
  • 87 Answers
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
  • 1122 Answers
SOURCE: how to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Posted on Apr 20, 2009
Maytag317
  • 1136 Answers
SOURCE: maytag washer stops at spin cycle
Hi, You can get to the lid switch by removing the screws that hold the control panel to the cabinet. This model has a fuse included with the lid switch.
I hope this helps you.
Please let me knwo if I can assist you further.
Vic
Posted on Jul 01, 2009
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Washer lid switch replacement
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
Lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
MY WASHER IS FULL OF WATER BUT WILL NOT START CYCLE. POWER IS ON TO THE WASHER
Need to replace your lid switch.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 18, 2008 | Whirlpool GSW9800PW Washer
DOES NOT TURN ON
need to replace lid switch.
Question about whirlpool catalyst 27" washer
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Apr 05, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
