Question about GTCO CalComp Creation Station Graphic Tablet
Creation Station Digital Tablet model 11050
Trying to reinstall tablet and am having great difficulty.  Am old senior citizen and have limited PC experience.  Would appreciate assistance that doesn't cost money.
0 characters
1 Points
ERROR message "A Supported Tablet was not found on the system"
I have encountered this message a few times, usually if I have tried to plug'n'play the tablet. A restart with the tablet connected usually fixes it for me, but I would suggest removing the driver and software and reinstalling them, making sure you have the most up-to-date version- freely available from (though I note you have the latest versions so just reinstall those).
I think, however, your problem might be something to do with the following note from wacom:771c281.png Do you know if you are running a 64-bit setup? There may be a workaround even if you are, so do let us know.
Oct 28, 2009 | Wacom Intuos2
Wacom tablet stopped working, blue light on.
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
Can I connect my old Mac's ArtZ tablet to a new PC using ADB-to-USB adapter ?
You can try the Virtual Tablet Interface from Digitizer Technology:
I haven't been able to get pressure sensitivity working in my drawing programs yet, but it does allow you to use the tablet in Windows 7.
Oct 06, 2009 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Hello! I own a Intuos3 Wacom tablet and I am having problems with it. My old laptop did not recognize discs, so I installed my tablet using one of the drivers from the download section and it worked just...
I'm getting the same problem - for some reason it's removed all pen pressure sensitivity recognition from the tablet. I'm going to try re-installing the drivers tonight, I'll get back to you if I figure it out.
Oct 03, 2009 | Wacom Intuos3 Graphic Tablet
Wacom tablet (Model ET-0405-U) Driver?
Wacom tablet drivers can be found at: Driver Update Software for XP Vista 7 8. Used it many times before. have a nice day
Oct 03, 2009 | Wacom Graphire Grape (ET0405UGRAPE)...
Genius MousePen 6x8 pen drags as if I'm holding down mouse button
Listen up kiddos! I had this same problem and I was troubleshooting....apparently you have to make sure you uninstall the old drivers first and delete the directory entirely, before reinstalling the software.
So, UNPLUG THE TABLET! This is the part that screwed me up... then go to start > all programs > tablet > uninstall. Run the wizard, restart, go to my computer > local disk drive > program files and delete the Genius Tablet folder. Then, install the drivers again, reboot, THEN and ONLY THEN, should you plug your tablet back in.
Mar 20, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Wacom Intuos 3 on Leopard No Longer Working
I had the same problem. Repairing permissions didn't help, but deleting old software and reinstalling new WACOM software did. Thank you, Swedey! :o)
Jul 22, 2008 | Wacom Intuos3 Graphic Tablet
Genius g-pen 450 driver problem
Try to change usb port and reinstall driver some port on your PC may not regcognize it.
After I solve it , everything work fine :D
Apr 15, 2008 | Genius EasyPen (K9418400)
GTCO CalComp Creation Station Graphic Tablet Logo
155 people viewed this question
Top GTCO Graphics Tablets Experts
Gareth Cockram
Gareth Cockram
Are you a GTCO Graphics Tablet Expert? Answer questions, earn points and help others
