Question about PANDIGITAL Photography
Pandigital LCD half showing - PANDIGITAL Photography
My granddaughter ordered a book from Barnes and Noble for her Pangital e-reader. Only half the book came over the lines. Could you help us. B&N said that we need to contact Pandigital
You need to demand B&N let you download the whole thing again for free, there is nothing pandigital could possibly do about it. Also you might want to thank them for giving you the run-around as well. Be assertive, it's all on B&N.
Jun 29, 2012 | PANDIGITAL Novel eReader
My Pandigital EReader is frozen, it won't even go into sleep mode.
My pandigital has been frozen on the pandigital novel options for 1 full day. How can i shut it down and read the books I have?
Jan 06, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Cannot see Pandigital drives when I connect to computer
connect PAN813-B to another system if it not show drive it may faulty,if it show then check compatibility of pan drive to your system, it support or not
May 04, 2009 | Computers & Internet
Not all jpeg images will load on 7'' Pandigital Photo Frame
I was having a problem too with my Smartparts frame. All the pics were from the same camera but some of the vertical (portrait) orientation shots wouldn't show right. Just a bunch of thin colored lines. After some phone calls I did try to "resize" the photos to the "resolution" of my frame (had to look that up too). My frame is 640 width by 480 high. So I took a shot and changed all the goofy photos to 480 width (since they were vertical) and let Photoshop change the the other number. Low and behold the buggers are showing up fine now. Well on to my next problem - focusing with the new D90. I think that one is going to be more challenging yet. Hope this helps you out.
Dec 30, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
The Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
Dec 26, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Nov 23, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Photography Logo
22 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
