Question about Video Game Consoles & Games
Godswar error problem
Error#:0 [0x0] Function:SceneManager::create_entity Description: Create mesh object failed with name obj001656.. File: M:\Easy3DStaticLib_Source\Easy3D\code\graphic\scene\SceneManager.cpp Line:89 thats what it sai
  • Laminous
    Laminous Jan 03, 2014
    thanks for the help!! Reallyyy helpful :3
  • 6 Answers
SOURCE: YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Posted on Aug 06, 2007
SOURCE: Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Posted on Aug 29, 2008
kiki-mad
  • 51 Answers
SOURCE: error 89
Error 89 is probably something wrong with it actually loading the new map. Theres probably a script error with the transition 'compasses'. I suggest cleaning the disk as well as possible (if you havent already tried), and, if that doesnt work, i think its a good idea to get a new disk.
Posted on Sep 13, 2008
SOURCE: yahoo mail login error
Im having the exact same problem. What do I do please to resolve it?
Posted on Nov 11, 2008
  • 2072 Answers
SOURCE: Xerox 7328, error 018-543 Shared name error in server
Prerequisites:
  • The printer must be connected to the network.
  • The IP address of the printer is required.
  • The HTTP option must be enabled on the printer. To obtain the IP address or to confirm if the HTTP option is enabled, print a Configuration Report. See the Related Items below for additional information.
  • A user account for the scanner must be created (account needs full control access rights).
  • A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
  • The Hostname of the workstation must be known.
Scan to File is set up in several steps:
  1. The first step is to make sure the scanning service is enabled on the printer.
  2. The second step is to set up the scan file repository.
  3. The third step is to create any necessary templates.
  4. The final step is to configure the template with the required settings.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary.
  1. Make sure the SMB port is enabled. Print a Configuration Report to verify this setting. See the Related Items below.
  2. Open an Internet browser window.
  3. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  4. If prompted, enter the username and password in the fields provided, and then click [OK].
    NOTE: The default username is "11111". The default password is "x-admin" and must be entered in lower case letters. If the username or password has been modified or forgotten, contact your System Administrator.
  5. Click on the [Properties] tab. The Properties options will be displayed.
  6. Click on the [+] next to Services on the left side of the window to expand the options.
  7. Click on the [+] next to Network Scanning.
  8. Click on [File Repository Setup]. The File Repository Setup window will be displayed.
  9. Click on [Edit] in the Default File Repository section. The File Destination screen will be displayed.
    NOTE: A maximum of five file repositories may be configured. Generally, just the default repository is configured for scan to file.
  10. Select [SMB] from the Protocol menu.
  11. Enter a descriptive name in the Friendly Name field.
  12. Enter the IP address or Hostname of the computer where scanning will be setup in the Hostname / IP Address & Port field.
    NOTE: The default SMB port is 139. Generally this port number does not change.
  13. Enter the Share name in the Share field.
  14. If necessary, enter the scan path in the Document Path field.
  15. Click on the [Prompt at User Interface] or [System] radio button from the Login Credentials to Access the Destination section.
  16. Enter the scan user name in the Login Name field.
  17. Enter the scan user password in the Password and Retype Password fields.
  18. Click on [Apply]. A “Settings have been changed” message will be displayed.
  19. Click on [Reboot Machine]. A "Do you want to reboot?" message will be displayed.
  20. Click [OK].
  21. Close the browser window.
  22. Test scan to file using the default template. See the Related Items below.
  23. If necessary, create scan templates.
Posted on Dec 16, 2008
I have an error message on My Invoices & Estimates when trying to save an invoice data saving error: Save Entity exception. It wont let me save it or back out of it... What do i need to do to correct...
Per Avanquest: We have found out that this randomly happens due to an interruption in saving the data in MyInvoices and Estimates Deluxe version 10. We recommend that you do the following steps:
  1. Go to the Task Manager.
  2. On the Applications tab, click on MyInvoices and Estimates.
  3. Click on End Task.
  4. Relaunch MyInvoices and Estimates.
  5. Create a new invoice/estimate and save it.
If that fails to resolve the issue, you should also try the following:
  1. Close MyInvoices and Estimates.
  2. Restart your computer.
  3. Relaunch MyInvoices and Estimates.
Note: The task you need to end is MIED.exe
This worked for me without losing any data other than the invoice I was creating. Always make backups so if your data file is corrupted, you can easily restore it. Hope this helps.
http://support.avanquest.com/support/solutions/articles/1000173898-when-saving-an-invoice-or-estimate-i-get-a-data-saving-error-message-how-can-i-correct-this-
Dec 06, 2012 | Avanquest My Invoices And Estimates Deluxe...
Activex component can't create object
Do the following tasks:
  • Reinstall Windows Script
  • Repair Windows Script File Information in Registry
  • Reregister Concerning File
  • Reset Internet Explorer Settings
  • Restore your Computer
  • Repair System Files
If you want to fix this error instantly then use a system utility software RegInOut to fix this error.
Hope it works for you.
Dec 22, 2011 | Computers & Internet
I get an error code when trying to complete the install of a new business. The error code reads; Create Company File Error, Exceptions: Save Entity Exception. I have windows xp, and I turned my antivirus...
ok you have to create a file with all the compay details try looking for a set up wizard.
thats the best i can offer as im not 100% oncertain types of software.
Oct 06, 2010 | Avanquest My Invoices And Estimates Deluxe...
Failed to Create print object
Step 1: Click Start --> Printer and Faxes --> Add a printer.
moz-screenshot.jpgStep 2: While wizard appear, click next and tick on A network printer or a printer attached to another computer. Click next.
Step 3: On the specify printer options, tick Connect to a printer to the Internet or on a home or office network. Specify your printer destination. Example: http://192.168.110.120/
Jan 30, 2009 | Lexmark X945E Printer
Not able to open Yahoo
Try clearing your browser cache.
Also, try turning your firewall off, see if you can get through, then turn it back on and try again.
Nov 20, 2008 | Yahoo Mail
Active directory
An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "dynamicdata.fabrikam.com". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
Dec 26, 2007 | Office Equipment & Supplies
Button script
how to link 1 frame to 6 frame with button give me script
Dec 01, 2007 | Macromedia Flash MX
Runtime '429' error
It sounds like your product is not compatible to Vista....you may need to email the creators of this product and ask them for the update if they have made one YET.
Oct 02, 2007 | Individual ResumeMaker Career Edition for...
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
