Question about Tricity Bendix AW1000W Front Load Washer
Not draining spinning the drum stopped turning could. hear a metal clicking noice unable to turn the drum by hand
I could hear a little grinding noise before the mashine stopped I could hear a loud noise before the mashine stoopedstopped
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Transmission is done!
Posted on Jan 04, 2014
3 Suggested Answers
  • 3 Answers
SOURCE: washing machine not spinning AW1000W
Could be that the drive belt has broken or come off. Empty machine of washing and water, UNPLUG! turn on its side and look underneath to see of the belt is still located on the motor pulley.
Posted on Oct 24, 2009
  • 901 Answers
SOURCE: machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Posted on Mar 31, 2010
Machine fills, then on entering wash cycle makes loud grinding noise kinda like a dull hacksaw on rusty metal.
Does it make the sound when you turn the drum by hand? It could well be the drum bearings that have gone.
Aug 01, 2016 | Washing Machines
XL7 has a clicking scraping noise on drivers side in reverse only. Have checked brakes and they look ok. When I put on jacks with the hub off and turn by hand I can still hear the clicking grinding
Where is the noise? Front or back? At the brake or differential? Usually grinding and clicking is the rear brake drums. Brake shoes/hardware. Year, make, and model?
Jan 26, 2015 | Suzuki XL7 Cars & Trucks
Spin - loud noise - switched off - drum wont turn
I'm just hazarding a guess here, but it sounds like the bearings have gone (if you try to turn the drum by hand and it sounds noisy and grinding/crunchy then I think it would be the bearings). I'm certainly no expert though.
Feb 02, 2014 | Zanussi Washing Machines
When i turn power button on ,it sounds like grinding metal ,very loud vibrating noise.
sounds like the bearings. make sure machine is off open door put your hand at the front of the drum at the top then see if you can lift it up and down if there is alot of movement it will most likely be the bearings,or try turning the drum by hand to see if you can feel any vibration or hear any grinding noise.
Jul 26, 2011 | Washing Machines
It has been making banging noises and the drum is sqeaking.the wash programme stops mid cycle we have drained it and cleaned the filter, it is a bit better but is still not working properley.
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | AEG Washing Machines
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Grinding niose towards rear of suburban when i coast. Does it every time coasting down hill or slowing to stop or turn. Echos through drive shaft at rear end.
GM rears are known for this noise it is usually caused by a pinion bearing that is coming apart or what they call bernelling ( I am not sure I spelled that correctly) it is little pits in the cones in the bearing it comes from lack of lubrication or the pinion seal leaking,you could pull the rear cover and drain the fluid into a dark pan and look for debris or alot of silver color.
Nov 15, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Drum breaks on 2008 Kia Rio 5 make a grinding/clicking noise when stopping i took off the wheel and turned the drum by hand and you can hear and feel a slight grind at one point in the rotation. How do i...
There are a couple ways. Sometimes the drum will have threaded holes in it in which case you just turn a bolt through the thread slowly until the drum begins to seperate from the hub.
Otherwise you can pick up a puller from your local auto parts store for about $10-15.
Good luck
Jun 18, 2009 | 2008 Kia Rio
Noise from drum when spinning.
can u move the drum up and down if so the bearings have gone
Feb 03, 2009 | Whirlpool AWM8163 Front Load Washer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
Tricity Bendix AW1000W Front Load Washer Logo
65 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
