Question about GE GFDS350ELWW Dryer
Power button moves around
The power button moves around and will not power on. Like it is off the switch
My unit does not power up when the button is pushed. Power is at the receptical.
As I recall, I found a unit in the dumpster and took it home to check out. I turned it on and had power display but no heat. Started looking around for model number and other info.
As I was moving it I heard oil sizzling. The unit has worked since then. There are bimetallic switches inside of them. They tend to stick. Moving it around (dumpster trip, my trip home) allowed it to return to its proper position (normally closed).
I have ran into this with many coffee makers, bounce them around a bit and the sensor will reset.
Hope this helps you!!
Aug 06, 2014 | Honeywell HZ-709 Oil Filled Radiator...
Power problem
Here are some ideas you can try when troubleshooting power issues with a laptop:
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on then you can be sure you have a bad DC jack or a bad AC adapter.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard.
8. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
Hope one of these ideas helps.
Thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Denon AVR-687 cannot power on, no power light lit around power
Check the main power switch next to the large power button. It is a small push button. If it is pressed in and you still have no light around the power button then very likely you have a dead power supply.
Apr 27, 2010 | Denon AVR-687
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
JVC Gr HD1 power/record button fell off and tape stuck inside
I have a solution posted on replacing the button in another Question but as far as your question; If you still have the button you can pop it back in (push in and hold tight) and move it to the position to turn it on. Once it's on you don't have to hold it in to keep the camera on. Only switching it to the off position will turn it off. Let me know if you lost the button and I can give you a work around for that (even if you still have the button and are jamming it in there but it's not working my workaround could help).
Jun 06, 2009 | JVC GR-HD1 Mini DV Digital Camcorder
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Driver power window button will not work to close window
check to see if the weather strip around the window has bulged together and is stopping the window. If so, try to strisghten out rubber strip while also moving switch to up.
May 18, 2009 | 1998 Buick LeSabre
1991 range rover passenger seat doesn't move
You could try swapping out the seat switch from the other side if you are just trying to move the **** portion forward or backward. What usually goes wrong is the seat switch gets corroded and needs to be disassembled and rebuilt. The opposite seat switch will no fit the other side and mount but you can finesse it around to a position where you can make connectioin.
To remove seat switches - Use a small screw driver to carefully pry up the button control knobs (**** and back knobs) on top of the switch housing. Next, remove the cover plate and there you will have 2 screws exposed to remove the switch.
Mar 22, 2009 | 1990 Land Rover Range Rover
GE GFDS350ELWW Dryer Logo
49 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
