Question about Sanyo Televison & Video
Won"t Power On
Good power source. No remote. No sign of any power on unit after power button pressed
SOURCE: No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Posted on Oct 12, 2007
SOURCE: centrex 80cm locked
there is a button on the remote that has a rectangle shape on it with a + inside the rectangle. Hold it down for 4 seconds or more.
Posted on Dec 18, 2007
djicenova
  • 319 Answers
SOURCE: Region Free CODE available HERE
awesome!
Posted on Apr 01, 2009
  • 28 Answers
SOURCE: CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Posted on Jul 01, 2009
SOURCE: Olevia Hi Def tv 242TFHD, won't turn on. Power
yes the capacitors your looking for are a 1000uf , 1500 uf , and on the other side of the heatsink a 680 uf. the tops will be slightly bowled. replace those with same type !not brand!, and youll be happy.(same thing happened to me, less than 2 years old also).
Posted on Dec 04, 2009
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Won't let me sign out
You possible have some windows problem which need to restart. Sometimes windows are so invalid that only press on reset button can help. If you don't have reset button you need to press power up button for around 5-6 second. If you have problem with viruses, it can be source of problem too. You will need to go to 'Safe mode with networking' (press F8 after start of computer every 1 second). Download ESET (Nod32) hand antivirus scanner, and try to scan your computer in that safe mode.
Aug 25, 2011 | Computers & Internet
How to unlock dvd
Here is how to unlock the HT-DS1000:
Step 1) Disconnect your player from its power source for 30 seconds
Step 2) Reconnect your player to its power source
Step 3) Press the Power On button on your remote control
Step 4) Press the Enter button on your remote control
Step 5) Press the 8 button on your remote control
Step 6) Press the 4 button on your remote control
Step 7) Press the 2 button on your remote control
Step 8) Press the 6 button on your remote control
Step 9) Press the 9 button on your remote control
Step 10) Press the Enter button on your remote control
Step 11) Your player should now place itself in Standby mode
Step 12) Press the Power On button on your remote control
Please rate my answer if this helps,
Many thanks,
Chris
Mar 14, 2011 | Samsung HT-DS1000 System
Region codes for Samsung ht z110
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
posted by alfredsaviou
Nov 18, 2008 | Televison & Video
Region Codes
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
It should also work for HT-Z310T and HT-510T and its variantes...
Apr 12, 2008 | Samsung HT-Z310T Theater System
Marantz Remote control model RC-18SR
Does the SOURCE ON\OFF button still work? If so, you can still use the remote to turn the receiver on and off by first pressing the AMP button (so that the remote window says AMP) and then pressing the SOURCE ON\OFF button.
Dec 23, 2007 | Audio Players & Recorders
Regional code change for a samsung ht-db120n
1) Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6) Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control. Your player is now region free. A word of caution is that you may have disc eject issues, in which case you will have to eject from the unit, or toggle the power switch on/off. This issue only arises if you have a particular chipset in your player (about a 20% chance).....good luck my friend.
Aug 01, 2007 | Samsung HT-DB120 System
Dvd-r problems
Unplug your AC power cord for a minimum of 30 seconds to clear the RAM. The RAM is used solely for dvd class history, and clearing this should solve your issue. If you want to convert your player to region free, which will allow you to play ANY dvd: 1 Disconnect your player from its power source for thirty seconds 2) Reconnect your player to its power source 3) Press the Power On button on your remote control 4) Press the Enter button on your remote control 5) Press the 8 button on your remote control 6 Press the 4 button on your remote control 7) Press the 2 button on your remote control 8) Press the 6 button on your remote control 9) Press the 9 button on your remote control 10)Press the Enter button on your remote control 11)Your player should now place itself in Standby mode 12)Press the Power On button on your remote control A word of caution if your convert your player is that disc eject issues may arise in which you will have to eject from the unit, or toggle your power switch on/off.....good luck my friend.
May 16, 2007 | Samsung HT-DB120 System
Televison & Video Logo
24 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
