Question about Panasonic Audio Players & Recorders
Panasonic sa pm45
My school uses a Panasonic CD player, but now the drawer won't close. I've opened it up and found nothing inside that seems to be blocking the drawer from shutting.
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
dahaka
  • 347 Answers
SOURCE: My Panasonic tape/CD player (SA-PM193,
Hello Rich,
If you say your Cd/ or something is stuckd inside your player,
First you should try calling Panasonic, (1-800-211-7262) Or in their website
What i will recommend you if they cant help you, or if your warranty has already expired is to take your Panasonic tape/cd player to a repair store.
If you want to try to fix it yourself, there isnt much i can help you from here if it is a jam. I would however suggest you to carefully take all the CDs/tapes out of it. Then when the only Cd left is the one jammed, turn it upside down, and try to carefully shake it and see if you can unjam it.
Good luck, and Thank you for using this service.
Posted on May 06, 2008
  • 319 Answers
SOURCE: jammed CD tray system
You may have a disk that fell out of tray onto lower mechanism. Be careful when disassembling mechanism as they have timing gears that are positioned to perform certain functions
Posted on May 07, 2008
abhishek33
  • 1239 Answers
SOURCE: I have a Denon DCM-380
hi  check in the link
  1. www.engadgethd.com/2008/07/09/ask-engadget-hd-which-av-receiver-has-the-best-upscaling-chip/   but I would expect the pre-outs to be active all the time. You shouldn't have to enable them. You might want to try redoing the audio configuration on your ps3 - select the HDMI connection then automatic configuration. thank u........................
Posted on Sep 11, 2008
Panasonic sa ak27 stuck in cd mode and cd drawer will not open
Unplug the unit then check to see if there is a small hole (1/16") on the front panel of the player near the open/close button. If so straighten a paper clip and press into the hole to open the drawer manually.
Jan 06, 2018 | Panasonic Televison & Video
DVD drawer opening when it shouldn't!
With the price of dvd players and yours bieng 6 years plus it make more sense to just buy a new one.
Jan 10, 2014 | Panasonic SA-PT460
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Panasonic dvd home theatre system SA-HT520. My 2 year old was playing with buttons on dvd player and now when i press open/close button it is saying locked and won't open, is there anything i can try...
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 29, 2011 | Panasonic Home Theater System System
Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Jul 20, 2010 | Philips Audio Players & Recorders
Multiregion unlocking code
Welcome to standalone DVD Player Region-free unlock guide. On our pages you will find a lot of verified working unlock codes collected from many different sources.
Whilst we made every effort to ensure that the information contained inside these pages is both accurate and up-to-date, we take NO responsibility and accept no liability for any damage caused from applying these procedures as laid down on these pages.
Use them at your own risk!
DVD Player model: Panasonic SC-HT80
Open CD drawer.
Press 9, 8, 1, 7 on the remote control.
Press ENTER till it shows region 9.
Press RETURN.
Apr 25, 2009 | Televison & Video
Novice
i/ve found that sony has the best single trays (and freq range)..i would stay away from multi cd players and any jvc (jvc freq range is horrible)...your speakers must match these componets....(bose, yamaha or customize )
Sep 14, 2006 | Panasonic SA-XR15 Receiver
26 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
