Question about Goodman CKL36AR36 Air Conditioner
Contactor replacement need wiring diagram for ckl36-1 contactor switch please
  • 2 more comments
  • yellowfast1 May 23, 2009
    This is a home unit goodman CKL36-1H, the contactor switch was taken out to be replaced. and there is two red wires two black wires and then the two wires from the thermostat and then the two lines in for the power. the switch taken out was a single pole and the one i have now is a two pole switch and i cant figure out were the wires go can you help me the single pole has a bridge on one side but the two pole doesn't so do i need to bridge this the person who took it apart cant be found and im lost on the wireing Thank you for any help you mite be able to give me Doni
    im sorry but this is way over my head i need a easier way to under stand and i need to know were all of the wires go there is two red two blak and the two that come from thermostat some one els removed them and i dont know were to put them Thank You Doni
  • Dennis Boxerman May 11, 2010
    If this is a residential unit, please describe what is currently there. Should not be too dificult to do the fix.
  • Robert Moller
    Robert Moller May 11, 2010
    Compressor Contactor ?
    Guru:
  • 1,524 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Contactors and Starters
Onmost single-phase compressors with a single-pole contactor, there is a solidbar on one side of the contactor instead of having two contacts. One leg ofpower passes down the bar to the capacitor and to the run winding. It passesthrough the run winding of the compressor and from common back to thecontactor. It lands on the load side of the normally open contact of thecontactor. At off cycle, line voltage will be read from one side of thenormally open contact to the other: Line 1 on the line side and Line 2 on theload side via the windings.
Thecrankcase heater will be attached to the contactor with one leg on the loadside and one on the line side of the normally open contacts. At off cycle itwill have line voltage applied to it and will heat the crankcase. Once thecontactor is energized, both the line and load side of the normally opencontacts become one. Since you cannot feed a load with one line of power, thecrankcase heater will not work again until the contactor opens. This is asimple way to turn the crankcase heater off during the on cycle and to turn iton at the off cycle. Exercise caution when checking this type of setup becausepower is always present on the load side of the contactor.
Posted on May 23, 2009
  • Robert Moller
    Robert Moller May 23, 2009
    I was trying to explain why you need that contactor with the bar. During the off cycle it heats the oil in the compressor to prevent refrigerant flooding which will cause compressor damage.
    If you insist. The Power leads from the switch go to L1 and L2.
    The leads from the compressor go to T1 and T2. The thermostat wires go to the coil contacts on either side.
I need to run a contactor ( 40 amps 3 phase ) with the help of thermostat..i have connected L1,L2 n L3 and output coneccted in T 1 T2 T3 . now how to connect A1 and A2 .... i want that contactor should...
1) Copy following links for illustrations showing timer controlling contactor in 3-phase environment:
http://waterheatertimer.org/How-to-install-3-phase-timer.html
http://waterheatertimer.org/images/3-phase-timer-diagram-24Vac-865.jpg
2) Substitute thermostat instead of timer for switching control.
3) I don't know what thermostat you have, or if it's functioning or the rating.
4) Which contactor do you have?
Do you have a 3-phase contactor??
Or two-pole single phase contactor?
5) Match thermostat output voltage with contactor voltage:
Thermostat output is 24 volt? Then use 24Volt coil on contactor.
Thermostat output 120 or 277 > then use contactor with same coil rating.
6) More information is needed.
I don't understand description of your wiring.
Add a comment and compare with illustrations sent, so I can visualize ... or attach photo and/or give product numbers so maybe I can locate wiring diagrams.
Jan 31, 2013 | Connecticut Electric Electrical Supplies
Wiring diagram for sunquest pro 24 tanning bed
I do not have a diagram, but the contactors are really simple. You have 2 power switches on top of contactor and 2 wires going to the coil. There should be 4 larger wires on top, 2 in and 2 out.
If any of the crimp-on wire fasteners are blackened, then have a trained technician to replace the fastener. If bed comes on when pushing down on contactor with a plastic ink pen, then check the timer by turning on the timer and checking the voltage at the Main Relay Coil. If no voltage, then the timer is bad.
Jul 31, 2012 | Wolff Sunquest Pro 24RS 220 Volts
I need to put a 24 volt coil relay in my furanace for an EAC and I'm not sure how to hook it up. I'm guessing the low voltage wires from the thermostat (w & b wire) will go to coil side and...
Electricians don't guess, they test.
Usually 'relays' used for HVAC are called contactors, for some reason.
1) 24Volt wires connect to coil. Make sure contactor coil is rated 24Volts or 24vac
Coil terminals are typically located on side of contactor.
Usually you can see small copper wires from coil that are soldered to these terminals.
Test across terminals with multimeter set to read ohms, and you will get ohm reading of coil.
2) The 120V or 240V wires connect to terminals located on ends -or- on top of contactor.
If there are three terminals, then check these terminals with multimeter.
Push down contactor to simulate the contactor turning on and off.
Hold contactor down and test terminals again.
And compare test results with same test from old contactor being replaced.
3) Open following link to see typical 24V coil contactor with DPST with 2 NO contacts
The contactor shown in diagram is similar to your contactor, except the contactor shown has 4 terminals for 120V or 240V. This is why testing contactor and comparing with old contactor is necessary.
http://waterheatertimer.org/images/ON-delay-timer-diagram2-300.jpg
Sep 20, 2011 | Honeywell International Honeywell...
I have a lighting contactor issue it's hooked up to a photo cell and it kicks on and off all day long. the photo cell was replace woth a new one and the concator still kicks on and off
the photocell needs a constant source of power on the black and white wires. you DO NOT switch these! The photocell goes through a self test each time the power is applied. if you need to install a load switch, put it in the RED wire line. See diagram for the ac contactor.
Oct 26, 2009 | Square D 30 Amp Lighting Contactor W...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
On outside compressor for whole house AC: Critters ate wires. Have Blk & Red power in from breaker. 24vac switched from thermostat. 1 contactor with 24vac coil(original). 1 Capacitor w/ 3 terms...
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Jun 25, 2009 | Heating & Cooling
Cutler hammer a10ano series a-1 contactor
There should be 2 contactors for forward and reverse. you have to wire them so that the power coming in will switch 2 opposite phases to reverse.
Apr 10, 2009 | Plumbing
Replace Contactor Relay on Rheem Air Condenser
I have a Rheem heat pump/airconditioner, Mod # RPFA-036JAS, that I have had problems with for at least 5 years and have paid over $1,000 in parts and service calls. I can vever recreate the problem when a tech is here. It usually happens in the middle of the night. I hear a Click, ckick, click sound, through the unit and it sounds like it is comming out of my air handler, but the outside unit also clicks at the contactor and the condensor cooling fan moter will start and stop about every half secongd or second. Both contactors have been replaced, the small one twice, one capaciter
has been replaced. I allow the unit too cool down and its alright for a few hours. That is difficult when the outside temp is below zero. HELP PLEASE!
Feb 16, 2009 | Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
487 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
