Question about Gorenje GV 62110 23 in. Built-in Dishwasher
How to fix water drain
No water drain at the end of the program
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 38 Answers
Plugged or broken water pump
Posted on Jan 04, 2014
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Program ends before full cycle leaving clothes in loads of soapy water, happened twice after once I had pushed end button while red with door lock in red
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect. If the inlet valve water pressure is low then the program might take more time and so result in a error. so check inlet valve flow. Also the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally check the drain pump, if choked the drain cycle will extend and result in error.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Hotpoint First Edition WMA22 Front Load...
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
My washer does not spin the clothes at the end of the cycle.
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
In this case as there is no spinning for drying at the end it is possible that the program cycle is not corrrect and so the voltage at the program ends must be checked before we suspect the controller unit.
Also check the rest of the cycle outputs with a multimeter.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Aug 11, 2011 | Washing Machines
Water is not going outside
Possible blocking of the drain outlet, possible blocking of the drain pump/valve.
you must also check if there is power to the drain pump/valve when the program come to an end to drain . If there is no voltage the program controller can be faulty.
If present the drain valve/pump must be checked, cleaned or replaced.
Jan 08, 2011 | Washing Machines
My Miele G646sc dishwasher is not heating the water and therefore there is deposit of water at the end of the cycle. Please help.
Both the issues seems to be apart. The loss of heating is due to failure of the heating coil, failure of the heating coil control relay , failure of the program controller unit.
All of this must be checked with a multimeter only if you are able to remove and check the control panel of the washer.
Secondly the drain pump/valve can be clogged and is not fully exiting the water after the program comes to an end as the time given to pump out is not sufficient due to low flow - clogging with dirt.
Remove the drain hose/ drain pump and clean the filters , reset the valve/pump to test.
Jan 06, 2011 | Dishwashers
This is my Model # WTW57ESVW1 In the normal wash cycle, the timing seems off. When you first turn it you can hear the water but it also seems the agitator is already going and at the end of the cycle when...
Seems possible that the program controller is not working in order of the sequence that is required of the program.
So you must check the connection contacts, clean and try if this helps or else a new controller might be necessary as many of them develop bad contacts on usage..
Check cost , if possible swap and confirm before you buy one to fix.
Oct 11, 2010 | Washing Machines
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Hot water tank leak
drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
May 24, 2009 | Water Heaters
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Gorenje GV 62110 23 in. Built-in Dishwasher Logo
127 people viewed this question
Top Gorenje Dishwashers Experts
Joseph Hoffmann
richie46
ray gallant
Are you a Gorenje Dishwasher Expert? Answer questions, earn points and help others
