Question about Ovens
Ge oven wiring diagram - Ovens
What's the wiring diagram for a GE wall Ovens digital readout
There should be a diagram somewhere on the oven. Usually on the top or back or if not, inside the terminal block cover where the electrical supply wires go into the oven. Make sure its turned OFF before you remove any covers.
Mar 13, 2016 | GE Ovens
Ge stove wiring diagram
Will any wiring diagram serve, or do you have a particular model GE stove in mind?
Oct 24, 2013 | GE Ovens
I need the wiring diagram of the oven for a ge hotpoint stove
There are so many different types of ovens and ranges that there are no free sites that offer anything that is worth while. If you take the back cover off of the control section of your range then you will find a very detailed wiring diagram that is specifically for your range. Hope this helps. Good luck.
Dec 03, 2009 | GE Ovens
PURCHASED NEW GE WB27T10327 OVEN CONTROL TORISAN ERCB3 DID NOT HAVE INSTRUCTIONS FOR A NON SELF CLEANING OVEN. CAN YOU HELP? JERRY
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
I need a wiring diagram for the replacement ERCU on the JKP27WW1WW oven. Our oven is from 1994 and the new 'clock' module (ERC3) is slightly different where it connects to the 'bake' and 'broil' contacts....
I am not sure if this will help you but I did find a fellow that says he has the adaptable diagram for an updated part on this forum :
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/15496-wiring-diagram-oven-control.html
Oct 30, 2009 | GE JKP27 Electric Double Oven
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
Ge spacemaker cooking center wiring diagram
1. usually green wire is ground, connct to the body for your
stove.
2. the white neutal wire should connect to the stove neutal, one
hot wire to the stove and one to the light.
3. be careful
Jul 05, 2008 | GE Ovens
Ovens Logo
65 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
