Question about General Electric Profile DPVH880GJMG 7.5 Cu. Ft. Gas Dryer - Champagne
Dryer starts but after a few seconds shuts down
  • GE Master
  • 2,483 Answers
In the last 6 months, I have fixed 3 dryers with your symptoms. In each case, after taking the dryer completely apart, I found it plugged up with a huge amount of lint. This lint was not caught by the filter screen, it had collected all over the inside of the machine. It required dismantling the machine completely to clean,. Each dryer then worked fine.
Be blessed.
Posted on Jan 08, 2014
  • Oscar Lawson Jan 24, 2014
    I called a dryer repair company and they found the very same thing. Cleaned the blower housing of lint. Dryer then ran okay for a while but then the very same problems occurred. Now they're telling me its the motor. But I am able to run the dryer for a cycle then it quits again. Then if I leave it for a day, the next time I use it, it does the same thing; runs a cycle then quits. Is it the motor or something else?
I HAVE A AFFINITY FRIGIDAIRE GAS DRYER THAT WILL RUN FOR 5 MIN AND SHUT DOWN NO CODE BUT IN THE TIMER MODE IT WILL RUN OK.
Posted on Jan 27, 2014
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Dryer starts up runs for a second and stops a few minutes later starts up runs a second or two and stops
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 05, 2014 | Amana Dryers
Ge front loader dcvh515efoww - dryer shuts off when put on heating cycle
Did you pull the dryer out or forward sounds like you may have pinched the exhaust which restricts air flow exiting the unit this will cause it to heat briefly shut down heat shut down and continue this cycle the fact that it worked before makes me think it something simple it will not tumble in any cycle if door switch not installed correctly.
Mar 21, 2014 | GE Dryers
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Dryer works for only a few seconds but then shuts off
You probably still have water collected and trapped in the vent somewhere leading to the safety shutoff. I would unplug it and remove any connections to the dryer and then turn the unit upside down to see if any more water drains out of it that was trapped.
May 14, 2009 | Kenmore Dryers
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
May 12, 2009 | Kenmore Dryers
Dryer runs as long as you hold switch
You already know whats wrong. the switch is starting to go bad. replace and all should be back to the norm.
Jan 26, 2009 | Dryers
General Electric Profile DPVH880GJMG 7.5 Cu. Ft. Gas Dryer - Champagne Logo
646 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
