Question about Canon PowerShot SD940 IS / IXUS 120 IS Digital Camera
Canon powershot sd940 is wont turn on with full battery
    Top Expert:
  • Canon Master
  • 6,702 Answers
How do you know the battery is full? Even when the charger says so, it can be the voltage is high enough, but the battery can't deliver any current.
Other cause; you did put in the battery the wrong way around.
Other cause; there is some dirt in the battery housing, blocking the work of the battery. Check if all contacts, from battery and in the camera are clean, shiny and free. If there is any dirt or oxide on the contact points, clean with a dry cloth. Never use sharp tools on contacts.
Posted on Jan 04, 2014
t00nz
  • 4738 Answers
SOURCE: My Canon Powershot SD450 won't
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 28, 2008
darntoothysa
  • 489 Answers
SOURCE: Canon Powershot PD630 will not turn on!
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Posted on Nov 01, 2008
SOURCE: camera wont turn on
I just posted that I have this problem as well. Then, after browsing further at Canon's site, I found a possible link between the memory card and the power problem. Sure enough, I popped the memory card out and reinserted it and the camera powered right up. I hope this helps others. . . .
Posted on Jan 05, 2009
SOURCE: Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
Posted on Nov 10, 2009
  • 1382 Answers
SOURCE: my canon powershot sd 1200 wont turn on.
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that does'nt work our for you , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you !!
Posted on Jun 01, 2010
Tip
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.usa.canon.com/cusa/consumer/products/cameras/digital_cameras/powershot_sd940_is#BrochuresAndManuals">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
on Dec 07, 2010 | Canon PowerShot SD940 IS / IXUS 120 IS...
How do I take HDR shots with the canon powershot sd940?
Ok, like this. Cameras don't have an option "HDR", they have the possibility of taking HDR photos.
HDR is a term used for taking pictures with good lighting and shadows - this you need to set yourself - once you have, you have HDR ;)
(High Dynamic Range)
Oct 03, 2012 | Canon PowerShot SD940 IS / IXUS 120 IS...
PowerShot SD940 IS / Digital IXUS 120 IS Digital Camera: My Digital IXUS 120 IS has lens error, with a mess...
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
May 16, 2010 | Canon PowerShot SD940 IS / IXUS 120 IS...
Canon PowerShot SD940 IS / IXUS 120 IS Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
