Question about Home
Bathtub is filled and will not drain at all.
We have been having a storm and filled up the tub. Now it won't drain in the slightest. We are thinking airlock maybe. Pipes don't seem frozen and the tub is pretty new so it shouldn't be clogged.
    Novelist:
  • 180 Answers
If the tub's drain seems to shut off 100%, and it opens properly, most likely you do have a pipe freeze-up problem..... especially if you don't have any other drains having problems. Somewhere below the tub you should have an elbow in the drain pipe.. I'm guessing that the freeze-up has taken place in the elbow... Do what you have to do to warm it up... However, if it's been really cold, a slowly dripping or leaking tub or sink, will quite easily freeze, where ever your first cold spot is...
Posted on Jan 04, 2014
KETOLACA
  • 4 Answers
SOURCE: Indoor jacuzzi bathtub problem
Just add 1/2 cup bleach to a full tub of clean water, turn on the jets.
Grab a small goldfish strainer / net and scoop out the moldy chunks.
Keep cycling the water until most of the chunks are gone.
Drain the rub, refill and add 1/2 cup bleach again, repeating the process.
The problem is caused by water left in the lines after use, and it turns moldy.
After each use...drain the tub completely, then turn on the jets for about 10 seconds. This will purge the lines of any standing water.
Fill the tub with clean water and cycle the jets with bleach once a week to prevent any further problem.
Hope this helps...it worked for me, I had the same problem.
Posted on Jan 27, 2009
  • 150 Answers
SOURCE: install bathtub without existing drain
it is generally not allowed under the water regs to discharge waste water into anything other than a drain.I would suggest you install a discharge pump, typically the saniflow type which will allow you to run the waste across the room and discharge the waste into the vanity basin drainage.Should you choose to install this be aware of the waste pipe configurations shown by the instructions
Posted on Mar 20, 2009
  • 15 Answers
SOURCE: my bathtub jacuzzi wont work. I reset the circuit
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Posted on Oct 04, 2009
  • 127 Answers
SOURCE: drain stopper in the bathtub has come off how do
the stopper just sits in the hole. When you turn the knob the cable operates the piece that raises and lowers the drain plug. The weight of it and the suction of the water is what seals it....provided the o-ring is good on the plug.
Posted on Oct 18, 2009
SOURCE: My bathtub drains incredibly slow. After a 5 min
First of all plumbers(at-least none that Ive EVER known ) would attempt to use any type of liquid drain cleaner/unclogger but having said that I did have the same problem and here is how I fixed it most tubs have what they call an over flow drain it is the round metal/chrome/brass thing that is on the bath tub under the faucet it usually has two flat head screws one on each side I took that off and the straightened out a metal coat hanger(as best as i could ) and tried to leave a little hook at the end then i put that end(hook-end) down the hole where the overflow cover was at (be aggressive/push/jiggle/twist/cram/...ect..wharever you call it) and you just might be surprised (I was) I pulled out ALOT of yucky Stuff..hair/goop..and whatever else that was(GROSS) anyway drain works fine now.replace the cover make sure that the side that has the cut out/hole is on the bottom when you put the cover back on (That's where the water goes in if the tub is overflowing(*before it actually overflows the water tries to run under/over that and down the drain)Now my drain drains faster than it did when I moved in here.Hope this helps you
Posted on Dec 21, 2009
Why does my geberit bath waste plug leak water?
It's adjustable. Remove the drain lever from the side of the tub. Now you can withdraw the whole drain assembly. Clean it well, then reinsert it to see if that fixed the problem. If not, try adjusting it longer.
Dec 24, 2013 | Geberit Bath Waste and Overflow Tub Drain...
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
Mar 31, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Hot tub mtor is on.....no jets....
you may have burnt the pumps up,pumps like that are water cooled they may have over heated ,you may need to replace the pump.
Jun 29, 2009 | Maax Calla 6042 Bathtub - 101058-000
Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
May 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Home Logo
57 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
