Question about KitchenAid KCMS145J Microwave Oven
Door will not open. Button release does not release the door latches.
Door to my kcms145j microwave will not open. the button goes in, but the door latches don't release.
    President:
  • 1,335 Answers
The plastic lever release is more than likely broken. You can order the part from
http://www.repairclinic.com/Appliance-Parts?s=t-KCMS145JSS0-%3d%3dc226g5
It's about twenty dollars.
Posted on May 22, 2009
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Cannot get door open (and there is food inside). Push button goes in all the way, will not release door latch
Disconnect from the mains supply.
Remove the cover and you will see how the latches lift.
Hope that helps.
Nov 15, 2010 | Panasonic NN-T993SF Microwave Oven
KitchenAid KCMS145J Microwave Door Latch Broke
I downloaded a parts schematic of the door latch assembly and thought I would determine the broken part, order a replacement and install same. As soon as I started to remove the shell of the unit to get at the latch assembly, I discovered non-standard fasteners are used. My wife advised me to stop and take it to a service center because she did not want me to mess up the containment of the radiation! Thanks for your interest. MB
Sep 04, 2009 | KitchenAid KCMS145J Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
1,380 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
