Leisure DWLT65 Dishwasher Logo
M
Martina Colclough Posted on Jan 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher will not start after being switched on- can you help
Richard C Cohen
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Leisure Expert 318 Answers
  • Posted on Oct 04, 2015
Richard C Cohen
Leisure Expert
Level 2:
Legend:
Answers
318
Questions
0
Helped
120698
Points
917
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
3answers
Bauknecht GSX 4756w when I switch it on and set the dial to the wash setting, I close the door and it sounds as though it is about to start but after 30 secs just starts beeping. When I open it the cycle...
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
pls do rate the solution
thanks.
regards.
fixya expert team
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Rotor wont spin
make this tests and fix it. God bless you
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Switch
Door Latch
Main Control Board
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Ariston Dish Washer LSE620A
test this steps and fix it. God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 • Dishwashers
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
When i close my dishwasher door it starts beeping
you need to replace door switch.adrian,,,,
2answers
My lg dishwasher beeps twice and wont start
If your dishwasher problem resolved or could you use more help? Please post back, no matter which. OK?
Dishwasher doesn't want to fill
Hello Dianne...I'll take a shot here.. chances are that the door interlock ( switch ) is disabling the dishwasher from starting.. it may be damaged or disconnected.. and as long as you are sure you have a water supply to the dishwasher,.. that's where I would start...If that switch is NOT made.. the dishwasher will not start... Hope that helps
Dishwasher -whirlpool
A series of tests that you can perform:
  • Check the door latch
  • Test the door switch
  • Test the timer motor
  • Test the selector switch
  • Test the motor start relay
  • Test the motor
  • If you found this helpful, Please vote. Good Luck!
    Top Leisure Dishwashers Experts
    Mike Cairns
    Mike Cairns
    Are you a Leisure Dishwasher Expert? Answer questions, earn points and help others
