Question about Coleman Mach III Air Conditioner
Not getting any cool air
I would like to know, if I can add freeon to this unit, as I am not getting any cool air. Or do I have to get a new unit , otherwise this unit work's good
  • inicis May 11, 2010
    What type of a/c is it? Central air, window unit, automobile?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Unit works good? Is the compressor coming on but not blowing cold air? If the compressor is running but not cooling, then the main issue is usually with cleanliness of the condenser. Wash it out if this is the case. If the compressor is not coming on, multiple problems could be the reason.
These units do not have service ports as a normal AC does. If you have lost freon then there is a leak in the system somewhere as they are sealed. The process for recharging a rooftop unit is usually expensive and not fail safe. I would recommend a new unit if a leak is discovered.
Posted on Jul 02, 2009
How do I add freeon to the unit
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Aug 29, 2011 | Goodman GMS90703BXA Heater
Who should I call to recharge AC by maytag? How much$? Add freeon...
Unless you see a big oil spot somehwere on the unit you do not need to charege it again and again . its sealed . is it just not cooling and hwat are the syntoms
Jul 22, 2011 | Maytag M6Q10F2A Air Conditioner
T Tair conditioner unit in our camper runs for a
the air filter may be dirty, if thats not it it is the condinser burned up and not pumping freeon
Jun 29, 2010 | Dometic Rooftop RV Air Conditioner
Ac works but not cooling. The thermostat dosen't work properly.
open unit an check the thermoprotector on the compressor thats the problem
May 16, 2010 | Friedrich CP12C10 Wall/Window Air...
What type of freeon gas does it take
There should be a nomenclature tag on the exterior of the unit by where the electrical enters the unit. It states the refrigerant type .
Nov 08, 2009 | Carrier 38CKC048 Air Conditioner
Air conditoner model gwhd5000 goldstar does not cool
Hi, first you will need to know, what type refrigerant,(freon) your a/c used, if you need to add freon, there's a leak in your a/c. you will have to find and repair leak, before you can charge/ add refrigerant(freon) . automobile a/c can be easily recharge (add) to system, but your window a/c unit, has the same principles but different approach, if you don't have experience, you will have to call mechanic, make sure you have a freon leak, before calling mechanic, plug a/c on let it work, put hands close to a/c, feel or check temperature of air blowing out from a/c, make sure compressor is working/running, fans could be working/ but compressor not, also put a/c thermostat to max, your model no. GWHD5000. means your unit is 5000 b.t.u, (british thermal unit) measurement of heat transfer, am wondering if a/c is to small for your space/room. making you think it needs freon, 5000. b.t.u. is for a small space,like a room 10' by 10' like a storage area or small bedroom, keep bedroom door/windows shut. measure you room/space/area , the bigger space/area needed to be cooled, has a chart, maybe you can find it on internet, any way a 10.000 or 12.000 b.t.u a/c is better buy, for normal room/space etc. so check compressor especially to make sure working, a/c could be to small for space/room, check it at night to see if it's colder. don't try to put gas/ freon yourself, could be very dangerous. but before calling mechanic, check those thing, mention before, could be your a/c are to small, for space/room etc. remember before attempting any repairs, disconnect power. good luck.
Aug 20, 2009 | LG Goldstar GWHD5000 wall/window Air...
The compressure kicks on, amd the blower works and it let me put the freeon in it once and thats all it let me know it dont work kno more when i add freeon? and it blows hot air
you need to have a repair shop do a leak check/test since you r losing freon somewhere if you have to keep adding it. Once it all leaks out it allows air to enter and air IS NOT a good thing for a/c systems. They run under an initial 30 inches of vacuum for freon charging.
Jul 26, 2009 | 2004 GMC Yukon
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Home Air Condition cooling problem
Hello. If your outdoor coils are dirty it's a good chance the indoor coils are dirty also. Clean the indoor coils and flush out the condensate line.
I know it's tempting to feel the air and try to decide if the unit is working properly but, you need to use a thermometer and while the unit is running check the temperature at the return air vent and then check the temperature at the supply vent closest to the unit. Remember to let the thermometer set for about 5 minutes before reading.
You should be looking for about 15 degrees F cooling between the return and supply.
If your coils are clean make sure the outdoor fan is operating properly. The air coming out of the outdoor fan should feel warm, almost hot. If not you may need to check your pressures. Good luck and let me know what you find.
Feb 03, 2009 | Ruud Central System Air Conditioner
Air conditioning unit
Hi! AC Unit
Sorry you have had so much trouble. Sounds like with the factory warranty being in effect the whole outside condensing unit should be replaced. With this type of problem there could be some blockage in the AC lines. With out some pressure reading it is hard to tell if the expansion tube is plugged, or there is some other major problem. If your service tech is unable to diagnose the problem you may need to get a third opinion. Goodman may have a factory representative in your area. You may be able to find some help with a different dealer or online. Good Luck! I will try and look for any changes.
InMrFxIt
Jul 28, 2008 | Goodman CLQ36AR49 Air Conditioner
Coleman Mach III Air Conditioner Logo
473 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
