My daughter seemed to spill some pickle juice on the front of my sanyo flat screen tv it ran into the bottom where the power and channel changing buttons are now it is wigging out and changing channels and settings it does it every once in a while what can i do
  • Televison & ... Master
  • 9,639 Answers
Spill a small amount of warm water and let it run down to wash out the pickle juice. Of course do this without the power cord connected. Let the tv dry long enough to be sure the water has evaporated before re applying power. Just might work.
Posted on Jan 05, 2014
4 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: spilled juice on front of Samsung LN52B750. Juice ran down into on/off control area. Now when it's turned on, no picture and channel display runs through non-stop on the screen. Any replacement parts?
HI,
To solve this problem you have to open your tv and using a hair dryer het the are of the control panel this will evaporate the moisture at the touch panle switches . After that reassemble the same and check. The problem will be cured.
ok
Posted on Dec 15, 2011
roety
  • 585 Answers
SOURCE: When I turn on my Sanyo 32
Hi my name is Roety,
I can help you with your issue ,
If you have already run the atuoprogram that programs and locks the channels in with a good cable or antenna connected then you may have a TV problem, but I'll bet its just not program yet.?
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Apr 14, 2010
  • 126 Answers
SOURCE: i have a flat screen element 32 inch tv and my
if your using cable then the tv is probably on an input instead of TV or antenna
Posted on Dec 04, 2010
My daughter spilled pickle juice down the front of my sanyo flat screen tv it seems that it ran down into where the control buttons are and now it is wigging out changing channels and settings periodically...
You have to disassemble the TV to take this board out, and must clean well. Never use water for cleaning. Use absolute alcohol or medical quality turpentine.
Jan 03, 2014 | Televison & Video
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
I have a 24 inch sanyo flat screen tv it is stuck on video and when I try to change the channel nothing happens I do not have the remote controller for this tv or any universal controller in general w
tried with unplugging and re plugging the tv doesn't work?. if not, tried to push any button like the channel up/down button and tv/video button at the front panel.
Oct 15, 2012 | Computers & Internet
Spilled juice on front of Samsung LN52B750. Juice ran down into on/off control area. Now when it's turned on, no picture and channel display runs through non-stop on the screen. Any replacement parts?
HI,
ok
Dec 15, 2011 | Samsung LN52B750 52 in. LCD TV
I have a small Sanyo television hooked up to a dvd player for my daughter....problem is I can't get it to go to the AUX channel. Don't have the remote that went with it, but do have a Sanyo FXMG...
Hello
Your sanyo TV has no menu button on its front panel control. Without its original remote, it is immpossible to get ito its AUX. OK.
Jun 13, 2011 | Sanyo DS13204 TV
My sanyo 42in lcd has just started acting up. I changed the batteries in my remote and now my tv turns on and off on its own and will not show a picture or sound. I cannot even change the channels. The...
Remove the batteries from the remote then see if the set returns to normal and you can use the buttons on the tv. If after the batteries are out and the set is still acting upreturns back to normal then the remote is bad, I have seen cases where something has been spilled on the remote and no one was told.
Dec 10, 2010 | Sanyo 42 in. LCD TV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
2 AV inputs, only 1 works at a time.
hello try using a scart block at the rear good luck
Jul 19, 2009 | Sanyo Televison & Video
Panasonic-36" Pana Black Tube - channels are continuely changing
I would suggest to let the water dry or you can use a hair dryer to blow air through the buttons, you could also open the back cover to blow air towards the front panel to dry it faster.
The spilled water is acting as a conductor, that is why the channels are changing on their own.
Good Luck.
May 26, 2008 | Panasonic CT-36HX41 36" TV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
