Question about Trio Stealth G2 7 inch Tablet with 8GB Memory
Trio Stealth G2 7" tablet wont turn on
The tablet was working fine for 3 days it had battery life when it was turned off now it wont turn on. we don't know if it is a charger problem or if something is wrong with the tablet. I have called the company but never have never talked to anyone because they never answer the phone!
My tablet was working fine the next day I went to use it I turned on it wont go past trio@9dualcore
if other solution fails, you can do a hard reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
try it, it works and start thngz afresh
Apr 04, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
How to fix trio stealth g2 stuck on boot ?
turn it off. if you can't then their is a reset button on the side where the charger is. Get a safety pin put it in the hole. You will know if you reset it. It will reboot. It won't effect your files or info. I hope this helps!
Jul 01, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
Tablet wont turn on
I was experiencing the same exact issue recently. I had to do a hard reset on my tablet. I was scared at first because I was told by some that I would lose all my apps, videos, music, photos, etc. Then others told me I would not lose anything. I did a hard reset and everything was restored.....nothing lost.
Mar 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio wont work!
try your charger with some other device
if its working then there is a problem with your charging ic
or processor
go to othorize service centre
Feb 01, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio Stealth G2 7 inch Tablet with 8GB Memory Logo
100 people viewed this question
Top Trio Tablets & eReaders Experts
Paul Wang
Andrew Taylor
Andrew Taylor
richie46
Are you a Trio Tablet and eReader Expert? Answer questions, earn points and help others
