Frigidaire gallery washer
I have a frigidaire front load gallery washer and when I start it no water comes in. We have checked for all the hoses, etc. and there doesn't seem to be any problems with them. Could it be the pump? If so, which? thanks.
    Novelist:
  • 180 Answers
Not likely that the problem is a pump.. Water usually comes into the machine under the normal pressure of your water supply. Hence, pump problems usually manifest themselves by not pumping the water OUT of a machine. First, check that the electrical power is coming to the machine. If it is.... and your water is definitely turned on..... you most likely have a problem with a switch, or relay or something else inside the machine.. Probably time for a repairman...
Posted on Jan 04, 2014
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
the dr
  • 447 Answers
SOURCE: Front Loading Washer won't drain
The problem is most likely change in the drain pump and sump area (rubber boot going from tub to pump). It is axcessed by removing the lower front panel. Disconnecting and reconnecting the hoses to the pump are real tricky!!!!!!!!!
Posted on Jan 16, 2008
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
My (gallery) front load is making my load dirty after the wash. I noticed that if I wash in cold water is not as bad as when I wash with warm/hot water.
Sounds like deposits or dirt coming from hot water tank or line running to washer.Turn off water supplies to washer and remove the hoses from the back to see if the filters/strainers in each port are dirty.If not add a little CLR to the washer and let it run a cycle.Hope this helps.Wouldnt hurt to check the drain strainer either on the bottom of the wassher if you remove the little access panel, might be something in there making water dirty
Jan 20, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Is there a water filter of the Gallery front loading washers?
Screens on the inlet hoses at the fill valve. None on the pump line going out.
Nov 17, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
During any cycle washer will stop and beep and flash E10. after pushing start it will continue, sometimes will do this several times in a load.
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Apr 18, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Gallery front load washer won't start
Call Service and have them come out.If it's new your our under warranty!
Good work done here.
A&E Factory Service
Nation Wide
7days/24 hours
They do Frigidaire warranty work.
Thank You for asking!
Please rate my, solution solved in this fixya site!
Neil
Aug 24, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigadaire front loader washer
Water not reaching the dispenser is one of the codes.
does it fill with water.
is it on a pedestal is the drain hose below the washer?
is it getting hot and cold water.
if water is not entering ,open the top and check the wiring to the water valves (where the hoses screw on)
Feb 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire washer {gallery series}
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
