Question about LG LFC23760SB Three Door French Door Refrigerator with Ice Maker 33 Width, Smooth Black, 22.6 cu. ft. Total Capacity, 15.5 cu.ft. Refrigerator Capacity, 7.1 cu.ft. Freezer Capacity, 4 Temperature Sensors, Door Alarm, Snack Pan, Cantilevered Shelves, Spi
LG LFC23760SB Refrigerator doesn't have power. The outlet is ok. Didn't have a power surge.
Opened the refrigerator this morning to find that the lights weren't on. I thought perhaps the door was left slightly open Then, I realized that I didn't hear the compressor or ice maker working. I checked the main circuit breaker, and it was normal. I checked the outlet, and it had power. The ice maker had become slightly noisier than usual. Could an issue with the ice maker cause the entire unit to stop working?
I think there is problem with your compressor unit. You need some maintanance or service of your refrigerator at regular period.
Posted on Jan 04, 2014
  • 221 Answers
SOURCE: LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jan 16, 2009
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Posted on Apr 30, 2009
  • 161 Answers
SOURCE: LG refrigerator compressor/lights won't turn on
You have a bad main board call LG service and discuss your options.
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: My LG LFC23760 Bottom Freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 04, 2011
imufo2
  • 3773 Answers
SOURCE: The ice maker on my LSC27950ST has stopped
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 05, 2011
My unit wont get cold, had power outage and think it needs to be reset. How do u reset compressor or unit?
See this video for the "reset" function of some refrigerators:
Easy Refrigerator Fix Reset Defrost Timer Switch if it stops running...
Does My Refrigerator Have Reset Button
How Do Reset My Frigidaire Refrigerator
Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
1800 Watts Refrigerator Surge Protector
Sep 01, 2015 | Refrigerators
Tip
Surge protector for refrigerator power
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair (refrigerator fan and main board). The board that was replaced actually had a burn mark on it where one of the components had fried.
Standard computer plug strip surge protectors may not be large enough for a refrigerator load. I used a plug-in surge protector that is made for use in offices for copiers and large printers since it has the capacity to handle a refrigerator load. Make sure it is one that does not cut off power so the refrigerator will continue to operate if the protector is overloaded or fails.
on Sep 18, 2009 | LG LFX25960ST Stainless Steel French Door...
LG LFC21760ST Beeping Constantly again. Last time it cost me a fortune to replace the computer board. Isn't there a cheaper way to stop the sound?
I would suggest starting with the easiest troubleshooting tip first. Try unplugging it for 10 minutes and plugging it back in. Most (modern) appliances will reset to factory defaults when they are unplugged for a few minutes.
May 29, 2014 | LG LFC23760SB Three Door French Door...
Emerson 2.8 Cu. Ft. doesn't automatically turn on after power outage
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
Feb 04, 2013 | Emerson 2.8 Cu. Ft. Refrigerator - Silver
Woke up this morning and the fridge was not working, It is like there is no power on to it. I checked the breaker and it was not tripped I did reset it to check but still nothing.
If there is not lights or anything in the refrigerator, then you aren't getting power. Start out checking the outlet - if you don't have a multimeter to check it, use a hair dryer plugged in to that outlet to see if it will work. If it doesn't then it is between that outlet and the main circuit breaker box or even a bad circuit breaker.
If it does work or you have lights in your refrigerator it is probably either the starting capacitor, start relay or compressor.
LG refrigerators are more sensitive to power fluctuations than other models and we have had to replace a lot of starting caps and relays - but sometimes it is the compressor.
Hope this helps!
Jun 22, 2011 | LG Refrigerators
I opened my fridge to get something out, shut the door and EVERYTHING WENT OUT??? No lights, no nothing??? I tripped the breaker and checked the cord etc... Nothing????
Make sure your getting power at the outlet by pluging in somthing like a hair dryer. If your getting power at your outlet then you probably have a controlboard problem.
If you don't have power then first look for GFI RESET in the kitchen. or fuse box.
Aug 11, 2010 | LG LFC21760 Bottom Freezer French Door...
Our power went out for a few minutes yesterdat and since then our refrigerator and freezer aren't working. What could cause this problem? -Thanks.
first of all I would check the outlet where your fridge is plugged in to make sure the power surge didn't affect it. maybe plug in a lamp. if it is ok, and the fridge will not start at all, i would check the relay/overload on the compressor as it may have been compromised by the power surge when the power came back on. these components start the compressor which in turn starts the cooling/freezing of your fridge. hope this helps.
Oct 13, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
LG LFC23760SB Three Door French Door Refrigerator with Ice Maker 33 Width, Smooth Black, 22.6 cu. ft. Total Capacity, 15.5 cu.ft. Refrigerator Capacity, 7.1 cu.ft. Freezer Capacity, 4 Temperature Sensors, Door Alarm, Snack Pan, Cantilevered Shelves, Spi Logo
160 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
