Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Fridge/freezer,wbm39 MS. Motor cuts out after about an hr.
Makes buzzing noise 4 a few seconds like its trying to start. motor gets hot..Help plz. Temp in cabinet comes down initially.
  • kevy114 May 22, 2009
    thx seabreeze, unit sold in newzealand, thx 4 your help.
  • Whirlpool Master
  • 4,655 Answers
You need someone to open the cover on the compressor and examine or replace the start relay, start capacitor and motor windings. One of those 3 are not working properly.Is the model number you gave made for and sold in the UK? Sea Breeze
Posted on May 22, 2009
  • John Tripp
    John Tripp May 22, 2009
    You are Welcome and Thank You!
  • pritz Oct 16, 2012
    hi itz me pritz, i have a problem about my fridge.. when i open my wbm39 am whirlpool, 2006 model alarm will easily blinking and when i close it. still the alarm still blinking. how can i know if the sensor of the door is working. but i cant see anything around the door. compressor motor and mother control board is working.
Motor runs for a few seconds than cuts out. No cooling
The startup capacitor is weak and that makes the overload switch kick in. You can get a 1/4 hp to 1/3 hp 3 in 1 hard start relay to fix that from graingers, or 1stsourceparts. EZ instructions.
Mar 10, 2010 | Refrigerators
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
The motor in my freezer makes a very loud noise and sounds like it is trying to start, it takes a few seconds before it stops the noise, then starts running the freezer.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 27, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Maytag fridge stops cooling, then 1-2 days later restarts on own
The buzzing is typically gonna be the compressor trying to start and failing. Am I right in saying the fridge is at least 12 or more years old?
Maytag used to use a compressor made by Tecumseh and they had a problem with starting. They would buzz and sometimes start back up. Sometimes in a few tries or a few days or never. It would continue to re try every couple minutes and last 5-10 seconds.
I would verify if it is a Tecumseh or an Embraco compressor then make your decision.
A service tech should be able to figure this out pretty easily! Normally what I would do is if I go in and it is running then I would turn it off and back on right away. the fridge will go through its restart sequence and typically make its noises then. Hopefully you are not being charged every time they come out
Compressors are the most expensive repair! and on these I always replace the discharge tube since they tend to rot out from sitting in the drain pan.
Let us know what you find!
Feb 21, 2018 | Maytag MFD2561HE Bottom Freezer French...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer and refrigerator not cooling. Makes a buzzing noise
hello sbarrry2 it sound like the motor that is running continously is the condenseer fan and the buzzing and then the click would be the compressor trying to start up and going off on overlaod. shut the unit off at the swiutch, let it cool down (3) hours possibly and then try to turn it back on. this should work. Thanks for using FixYA
Dec 26, 2008 | Maytag MTB1891AR Top Freezer Refrigerator
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
326 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
