Question about Envision G918W1 Monitor
Monitor says out of range
When I turned my computer monitor on, it said in the middle of the screen out of range. My home screen was all blurry. What would cause this?
    Problem Solver:
  • 9 Answers
If you are connected to a started computer, the resolution of your display adapter is not supported by your monitor. To solve this, you must restart your PC in safe mode and change the display settings (right click on the desktop/Properties/settings tab and you must try for the begining with a lower resolution, for example 800x600).
To start the PC in safe mode you must press the F8 key (or check the key for your operating system) before the OS loading (imediately after the PC starts or after the reset/restart) and than select the safe mode VGA.
Posted on Jan 04, 2014
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    "Out of Range" message appears and the icons are blurry.
    Out of range means that you selected the resolution that your monitor does not support.
    Your monitor works on 1440 x 900 / 75 Hz.
    right click on blank space on desktop and select screen resolution. Put it on 1440x900.
    Jun 19, 2010 | Envision G19LWK Monitor
    Out of range blinking in the middle of the screen. how do i get rid of it?
    You need to set your PC video resolution to the native resolution of this monitor: 1280x1024260Hz. I f you still get the message with correct setting then you may have logic problem, also try to use factory reset mode.
    http://s807.photobucket.com/home/budm/allalbums
    Apr 04, 2010 | Emprex LM1704 17" Monitor
    The screen is blurry on the top, bottom and sides, but the middle is somewhat clear. how can i fix it? thank you for your time!
    open the monitor a black EHT will found see the preset set it by screw driver on line see result on the screen the name on preset is FOCUS
    Nov 13, 2009 | IBM E74 Monitor
    My computer doesn't start up and when it does my screen has dotted lines and sometimes it starts but when it does only in a matter of time because after a few hours the screen of my computer will become...
    Sounds like a monitor issue at this point (blurry screen). Try switching monitors to see if same problem or test your monitor on another system.
    If not the monitor, could be video card or driver. It possible that you have spyware or malware, also. If not the monitor, when the computer does start, go into Safe Mode (F8). If Safe Mode loads OK, select a System Restore point from a date when all was OK. Hope this helps.
    Jul 09, 2009 | Microsoft Windows XP Home Edition with...
    MODEL DELL 1504 FP
    I have one with no backlight. The capacitors on the board are bulging. In my opinion they were designed too close to tolerance and "cooked out". As long as it's still working change the ones in the Regulator circuit(3 in the middle of the heatsink area), and the four really small ones over by the transformers. Should be right as rain.
    Aug 18, 2008 | Dell UltraSharp 1504FP Monitor
    Re: CTX monitor getting blurry
    Hi Beth,
    Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
    Apr 08, 2008 | CTX PL 9 19" CRT Monitor
    Image/screen shifting with mouse position
    I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
    Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
    INPUT SIGNAL OUT OF RANGE
    some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
    It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
    Dec 26, 2007 | Relisys TL775 17" LCD Monitor
    ENVISION EN-985E MONITOR PROBLEM
    When using this monitor on a PC running Windows Vista Home Premium the screen text is blurry and hard to read . I have tried working with the Clear Type in Vista and that does not help . I have reloaded the driver for this monitor and this did not help either . Any suggestions ?
    Steve
    Dec 05, 2007 | Envision EN-985e Monitor
    Envision G918W1  Monitor Logo
    56 people viewed this question
    Top Envision Computers & Internet Experts
    Cleverer2
    Steve
    Martin Murray
    Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
