Question about Video Cameras
The broken wire I found inside my Tablet.
I had my Tablet freeze up on me on my Android Logo. I was advised to remove the battery for 1 to 2 minutes and then put it back in. I removed the back of my Tablet and started to remove the tape from the battery very gently. Then one of the wires fell away from the battery and I instantly closed it back up. I want to get my Tablet fixed or replaced. I received this in good faith and I'm very upset. Please let me know if I'm suppost to send it in and how and where. Thank you Loralee Shipley
  • Video Cameras Master
  • 4,870 Answers
Return it to the original vendor
Posted on May 26, 2017
  • 188 Answers
SOURCE: Power failure and I need to remove tape
If you can do the repairs yourself there are two ways to fix the problem. Dismental the camera. Try to locate the power board. have a keen look at the components near the battery connector or the power connector. there you will be able to locate 3 to 4 safety fuses. check the continuty. if found open replace it and the problem can be solved. AND the other way is to locate the motor for tape deck loading mechanism. Remove the flex ribbion connector of the motor from the pcb, then try giving 3volt supply from an external device to the motor in both the direction. in one direction it will move the deck outward, but be carefull when the cassette is being ejected a little portion of the tape may get damaged.
Posted on Sep 25, 2006
JoeO700
  • 80 Answers
SOURCE: in video mode ERROR CODE MESSAGE E01
EO1 is a load motor timeout error. This is normally caused when part of the transport is locked or jammed. A defective tape can also cause this error. The mechanism is attempting to move and is not being allowed to for some reason. Repeated attempts at running the camera in this state will cause the fuse to open in the regulator circuit. Have an experienced tech look at this for you. Good luck! Joe Weibel Customelectronics.org
Posted on Feb 13, 2007
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
  • 274 Answers
SOURCE: tape won't load
There are different designs on how this works. One design there is a small pin inside that detects if you have the right tape installed. It has a very small spring which allows it to move back and forth it may have broken with normal use. (it happens) With a small flashlight look very carefully inside. You may or may not be able to see it. It may be located under the alum carrier and hidden. Worth a look. If you find it try to reattach the spring if in fact you see it. But I doubt you can because you need to get goo access to it. In any case, you most likely will need to take it in for repair. The tape carriers for these cameras are fragile and easily damaged. Wish I could give you and easy fix.
Posted on Sep 16, 2007
SOURCE: Canon GL1 Remove cassette error
I certainly don't intend to be rude or obnotious but your comments on this known prpblem are contraditory to say the least! :
"The problem that you are experiencing with your Canon GL1 camcorder is a common complaint on this model camcorder. The “eject the tape error” is the camcorders way of saying something is wrong and it needs to be sent in for repair. It is not a defect with the camcorder, it is simply the most common complaint when the mechanical assembly is not running smoothly and perfectly." If something is wrong and it's a common problem then it must be defect?!?! Also your pricing for this "repair" is pretty close half of what a used GL goes for over here in Europe. I would definatly be looking for another quote and repair service other than yours!
Posted on Aug 20, 2008
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    My tab stucked during start and its freeze in lenovo logo
    Android Tablet stuck on boot screen ! Bypass it in easy steps ...
    ? 4:36
    https://www.youtube.com/watch?v=HErn0-GcQqE
    Jan 4, 2014 - Uploaded by My Tablet Guru
    If your Android tablet is stuck on startup or boot screen, then bypass it ... 1) Press the volume up or volume down or home button when the tablet start, .... is support on my tab . its also stoc on android logo plz bro help me . .... How to fix most tablets if they freeze - Duration: 2:21. by JunkyBlake 236,241 views.
    Lenovo Yoga 8 Tablet stuck on boot screen - Lenovo Community
    forums.lenovo.com > ... > Lenovo Tablets > Android Yoga Series Tablets
    Apr 21, 2014 - I have the exact same problem with a yoga 10, it is stuck on the lenovo... Yoga 8 was working fine last night but today it's stuck on boot up with ... lenovo tablet a3300 gv stuck on lenovo logo
    May 17, 2015
    Stuck in Lenovo Screen - G500
    Apr 6, 2014
    Lenovo IdeaPad A1000 stuck on recovery mod
    Dec 23, 2013
    ThinkPad hangs on boot - stuck at Thinkpad screen
    Feb 2, 2012
    More results from forums.lenovo.com
    Dec 21, 2015 | Lenovo Computers & Internet
    My daughters my tablet2 by bush has,frozen what do I do
    if you can remove the battery start there. is not try to hold the power button for 1min. if that still doesn't work follow the bellow instructions
    When Hard Reset is Necessary for Smartphones or Tablets ?
    1. Forgotten Pattern Lock on Android Tablets or Smartphones.
    2.Too many pattern attempts / Reset user lock.
    3. Tablets PC,Smartphones stuck on Gmail account.
    4. Android Tablet PC stuck / freeze on Android logo.
    5. Tablet Android or Smartphones hang on start-up / Multiple errors generating by OS.
    6. Android market having problems or generating errors.
    7.Upgrading to new Android version.
    Make sure to charge battery upto 60%.
    How to Hard Reset Argos CnM TouchPad Android tablet pc ?
    • Make sure the tablet is charged up to 60%
    • Turn off the tablet completely .
    • Press Volume + button , while holding Volume + button , plug in charger.
    • Release the volume + button.
    • Press Volume + again and press Power button to boot the CnM Tablet.
    • When Android logo appear , release the volume + button.
    • Press Power Button again and press volume + button , Recovery Menu will be appear .
    • Press the volume down and select "wipe data/factory reset"
    • Power button to select it
    • You will see "Yes - delete all user data"
    • Select "Yes"press "Power" button to select it
    • Formating will start. it will delete all user data .
    • Few seconds later, you should see the recovery menu again. Select reboot.
    • It will take approximately 2 to 3 minutes to take you back to its factory (out-of-the-box) state .
    you are done.
    This Hard Reset method will work with all models of CnM touchpad tablets.
    Jul 25, 2014 | Audio Players & Recorders
    China Android Tablet not booting after Android logo
    reflash the firmware! either ur bootloader or ur boot.img seems to be broken. (hope 4 you, got a backup)
    Feb 20, 2014 | Allwinner A10 Android 4.0 7.0inch Multi...
    Froze on the Android Logo
    Try removing the battery for a minute or two. Anything you where working on that was not saved will be lost but when you re-power it, it should reboot with all the factory functionality.
    Dec 17, 2013 | Tivax Michley Mitraveler 10-inch Android...
    Tablets wont boot up just shows arnova on screen and shuts down
    I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
    How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
    Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
    To access Recovery mode on the ARNOVA 10bG3
    To access to the recovery mode:
    1. Hold down the volume button + and press the ON/OFF button.
    2. Once the boot logo ARNOVA is displayed, release the volume button +.
    The ANDROID green robot is displayed.
    3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
    The Android system recovery screen is displayed.
    a. Use the volume buttons to navigate
    b. Use the ON/OFF button to select an option
    To restore the default parameters of your tablet:
    1. In the Android system recovery, select Wipe data/factory reset;
    2. Select Yes -delete all user data.
    3. Select Reboot system now.
    Your tablet reboots. Redefine your parameters through the wizard.
    Your tablet is restored to its default settings.
    To access Recovery mode on the ARNOVA 9G3
    1. Hold down the Home button and press the ON/OFF button.
    2. Once the ARNOVA boot logo is displayed, release the Home button.
    To access Recovery mode on the ARNOVA 8cG3/8bG3
    1. Hold down the volume button - and press the ON/OFF button.
    2. Once the boot logo ARNOVA is displayed, release the volume button -.
    Sep 16, 2012 | Tablets & eReaders
    Android vimicro logo stuck on screen
    ANDROID Tablet Freezes at Android startup screen
    For Superpad VI - 10.1" Android Version 4.03, this worked for me!
    1. Press & hold START button
    2. When "VIMICRO" appears, Then Press & Hold the MENU button
    3. The Android System Recovery <3e> Menu should appear
    4. Scroll down using the Volume Key to "wipe data/factory reset"
    5. Press HOME Button
    6. Scroll down to "Yes - delete all user data"
    7. Press the HOME Button
    At this point the system will do a recovery and hard start, and will be on "reboot system now
    8.Press the HOME Button
    Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
    Apr 03, 2012 | Tablets & eReaders
    Android tablet screen freezes
    I have an apple android tablet and it freezes at the android with black backround
    Jan 26, 2012 | Tablets & eReaders
    Video Cameras Logo
    41 people viewed this question
    Top Video Cameras Experts
    Are you a Video Camera Expert? Answer questions, earn points and help others
