Question about Natural Rubber Hand Brush For Removing Pet Hair, Furniture, Carpet"
I need to remove a heavy TV - Natural Rubber Hand Brush For Removing Pet Hair, Furniture, Carpet"
  • Wendy Sip
    Wendy Sip Jan 05, 2014
    The TV is an old Sony Trinitron, from around 2000. It is at least 200 lbs. The TV is at the 2nd floor of my house...I need to find a company/individuals who can get rid of it for me.
    Problem Solver:
  • 9 Answers
Hi Wendy,call Goodwill or a Thrift store in your area and tell them you have a free t.v but they have to remove it.
Posted on Jan 05, 2014
How do i remove the stand on my 46" apex?
Your Apex TV stand is attached to the back of the TV by screws. Your Apex TV is large and heavy. It should be placed face down on a soft surface such as a blanket for removal of the stand
Dec 14, 2012 | Apex Digital Televison & Video
How to fix vertical burns on screen
First of all, change the input device to some other which you know for sure works well. Look for loose contacts in jacks, sockets. Check whether you have kept any magnetic material on top or near the TV. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Emerson LC320EM8 32 in. LCD TV
Does it come apart to move (ps80690)
yes it does look behind the tv. you will find two wholes, one on each side . put your hand in , and feel the top of the whole threw the inside, you will need to remove the bolts on both sides, you will need two people one on each side to lift the screen from the base, notice the hinges on the back , grab the hinge with one hand and place your other hand on the front and lift carefully , DANGER very heavy...
Apr 12, 2011 | Proscan PS80690 TV
How do i remvove the pedastal from a panasonic viera t
Typically, there are two large Phillips screws located on the rear of the TV.
Remove the screws, and lift the TV straight up. The pedestal should stay on the floor. If not, gently try and pull it from the slots in the bottom of the TV.
Please have a friend help you, as the TV is very awkward and heavy!
Feb 28, 2011 | Panasonic Viera TH-50PZ85U Plasma TV
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Tv is on stand by and I can not take it off
Push channel or power button on TV remote or TV itself to turn it ON, if still it wont turn ON, unplug it for few minutes and try again.
Still does not turn ON, let me know exact model number to find out problem reason and intimate does standby light flashing? if yes, how many times its blinking.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
Moving
I believe that is a rear projection type and if you take base off it MAY mess up your picture completely. It would probably be best to buy or rent a dolly or large wheels cart to put it on and move.
Aug 30, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Natural Rubber Hand Brush For Removing Pet Hair, Furniture, Carpet" Logo
49 people viewed this question
Top Evriholder Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Evriholder Vehicle Part and Accessory Expert? Answer questions, earn points and help others
