Question about Acer Aspire 5100 Notebook
The lcd inverter appears to be out no backlight can hear audio and see screen in light also the usb and the touchpad does not work
I have this laptop Im working on that the lcd inverter appears to be non functional at the same time the touch pad and usb does not work. I try to install th proper diver and get errors like the hardware is not there I suspect mother boar failure or somthing within the chip set...... any thoughts out there??
  • Acer Master
  • 32,281 Answers
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 22, 2009
Why is my replaced lcd screen not lighting up?
1) Wrong LCD screen
2) Video Cable (LCD Cable) is not connected tightly.
Motherboard side, or LCD screen side; or both.
3) IF, a screen Inverter is used, the small cable from the Video Cable, that connects to the screen Inverter; is not connected, or has a loose connection to it. (screen Inverter)
4) An LCD screen, and a screen Inverter are a Matched unit.
If it's the wrong LCD screen......................?
5) IF, a screen Inverter is used; the diagnosis was wrong, and the LCD screen was replaced.
90 PERCENT of the time, the fault is a bad screen Inverter.
A) Laptop's LCD screen uses a CCFL, (Or more than one), for a Backlight; the laptop uses a screen Inverter.
Diagnostic flowchart leads from Graphics Chipset, to Video Cable, to screen Inverter, THEN, LCD screen.
Expensive LCD screen was replaced, instead of the actual part that needed replacing;
Video Cable: $9 to $22
Screen Inverter: $9 to $22
LCD screen: $60 to $245
B) Laptop's LCD screen uses LED backlighting, and does NOT use a screen Inverter:
Diagnostic flowchart is;
A) Video Cable;
A Video Cable should have it's connections PHYSICALLY checked.
You have to try to push the connectors in tighter.
Visual inspection alone will NOT do.
Making sure the Video Cable connections are tight, and this does not fix the problem, then the Video Cable needs to be removed; and every wire in the Video Cable checked for Continuity with a multimeter set to OHM's. (1K)
Not feasible, then take the Video Cable down to the nearest small computer shop; and have the resident tech check it for Continuity.
Should only be a few bucks.
Or just replace the Video Cable.
(Parts changing I know, but...........?)
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little large than 1/16th of an Inch.
Average thickness is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
As previously stated, Backlighting that uses CCFL, uses a screen Inverter.
LED backlighting MAY, or MAY NOT use a screen Inverter.
When the LED backlight technology first came out, it seems some did use a screen Inverter.
It also seems as the technology advanced, LED backlighting does Not use a screen Inverter.
Regards,
joecoolvette
May 14, 2013 | Sony Computers & Internet
Brightness buttons (f2 and f3 are not working
Not a lot to go on here, Prabhdeep
Need the full model information
Example,
Acer Aspire 5535-5050
Post back in a Comment, or Reply; at end of this solution
Primer:
An LCD screen does not produce light,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor icon
Because of this the LCD screen needs an additional light source.
CCFL = Cold Cathode Fluorescent Lamp (Bulb)
Average thickness is 2mm, or a little more than 1/16th of an Inch.
Or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
(Do they break easily when trying to remove, and replace?
OH, YES!)
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
If the laptop uses LED backlighting, it MAY or MAY NOT use a screen Inverter.
Generalized thinking (Can also be stated as 'Rule of Thumb'), is that if the laptop uses LED backlighting, it does NOT use a screen Inverter.
I also feel into this line of thinking, since none of the LED back-lit laptops seemed to use a screen Inverter; that came to the shop.
I have found this to be a fallacy from on here,......FixYa.....
I have looked up two laptops using LED backlighting, and discovered they also used a screen Inverter.
Now I post LED backlighting may, or may not use a screen Inverter.
Seems when LED backlighting first came out, a screen Inverter was used on some models.
Also seems as the LED backlighting technology progressed, no screen Inverter is used.
90 PERCENT of the time, the fault for bad Backlighting can be attributed to a bad screen Inverter.
Of course, this IS IF the laptop uses a screen Inverter.
For a laptop with LED backlighting that does not use a screen Inverter, and backlighting is bad (Dim, or non-existant), the next hardware part in the diagnoses to replace, is the LCD screen.
I now await the information I asked for above.
Then we can diagnose together.
Regards,
joecoolvette
May 09, 2013 | Computers & Internet
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
Lap top dark screen, with system working fine. plugged on external vga, it works.
90 percent of the time the problem is the Inverter.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
Similar to the Fluorescent lamps used in home and businesses, but on a MUCH smaller scale.
(General size is 3 to 5 inches in length, and half the thickness of a No.2 pencil)
An Inverter is used to provide power for the LCD screen, and the Backlight.
An Inverter reduces the power coming from the laptop, for the Backlight.
An Inverter increases the power coming from the laptop, for the LCD screen.
An Inverter is a small circuit board located inside the Display Assembly, behind the Bezel, and usually towards the bottom of the LCD screen.
This is a typical example of an Inverter. It is NOT THE Inverter that you will need.
You have to match the Inverter to the LCD screen. has to be THE Inverter.
http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=2432
Post in a Comment as to the Model Number, and LCVD screen size of your Acer laptop.
(LCD screen's are measured diagonally. From corner to corner)
Nov 24, 2010 | Acer Computers & Internet
My laptop screen went black every thing is working but i cant see anything what might be the problem
hold the unit slihtly to a light if you can see the icons dimly on the screen then your screen has gone into freeze mode if you cant see the icons then your screen is probly blown to reset the screen from frozen it needs to be un plugged from the motherboard and plugged back in the plug is located under the panal above the keys
best luck
Oct 14, 2010 | Computers & Internet
JVC LT-37X688 37 in. LCD TV. When powered on there is a brief flash of light on the screen and then the screen is black and stays black. Audio is fine and I can still use all of the remote controlled...
No lamp on LCD tv.The LCD backlight inverter board it dead,that board needed replaced to get picture back.Tries Shopjimmy.com,Ebay.com to buy the LCD backlight inverter board.It usally a long board.The refurbish LCD backlight inverter board about $100-$120.
Feb 14, 2010 | JVC LT-37X688 37 in. LCD HDTV
The screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
Acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Aug 14, 2009 | Acer Aspire 5610-4648 Notebook
Laptop keeps shutting off. DV1490US. There is power in the case but not in the screen. I press the on button fo a while until all the lights go off inthe laptop and repress the same button. Sometimes...
May 23, 2009 | HP Pavilion dv1000 Notebook
Acer Aspire 5100 Notebook Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
