Question about Carl 12250 bidex heavy-duty rotary trimmer, 14-1/2 x 37 base, 25 cut
Trimmer doesn't cut the paper
The trimmer won't cut the paper.
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
Stihl FS 36 trimmer doesn't have power, won't rotate.
Hi, remove the wire screen from the muffler outlet, regards Phil.
Jul 01, 2012 | Stihl Garden
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
My cub cadet bc210 weed trimmer is stalling and the thread spool does not turn to cut. It is brand new and just taken out of the box. What to do?
Double check your assembly. If it still doesn't work, take it back and exchange it or get your money back.
Apr 30, 2012 | Garden
Won't cut anything
we have had this problem many times with our hair clippers
take off the outer blade and make sure it is all clean and there is no hair within the working when rebuilding add a little regular household oil
on the side of the trimmers there is usually a little plastic screw built into the casing this is the motor adjustment turn it until the trimmers become noisy then turn back half a turn so it lowers the noise out put hence the motor speed hopefully this should work
Dec 14, 2011 | Conair HC117 Hair Trimmer
Where can I get the blades sharpened? Marco Stratford CT 06614
you can do it yourself with instructions from ehow.com. see below OR you can get it done at a small engine shop repair, where they fix the lawnmowers, slingtrimmers and chainsaws such as Makita, shtil or any other company that makes them. Hope this helps!
How to Sharpen Hedge Trimmer Blades Instructions Things You'll Need
  • Metal filer Eye protective goggles
  1. Sharpen Your Shears
    • 1 Place the hedge trimmers on a flat surface. Ensure that the blades are pointed away from your body.
    • 2 Position a pair of pliers around the bolt on your hedge trimmers. Clamp the pliers on the bolt securely.
    • 3 Twist the bolt counter-clockwise to remove it.
    • 4 Separate the paired blades.
    • 5 Hold one of the handles with the blade facing away from you. Slide a metal filer down the length of the blade until you reach the pointed end. Continue to sharpen the blade for a minute or two, and then do the same with the other blade.
    • 6 Test the blades with a piece of paper. Hold a piece of paper next to the blade, and then try to cut the paper without using a lot of force. If the paper slices easily, then your blades are completely sharpened. If the blades do not cut the paper, continue to sharpen the blades with the metal filer, and repeat the paper test.
Sep 13, 2011 | Black & Decker 16Inch Hedge Trimmer
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
Carl 12250 bidex heavy-duty rotary trimmer, 14-1/2 x 37 base, 25 cut Logo
218 people viewed this question
Top Carl Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Carl Office Equipment and Supply Expert? Answer questions, earn points and help others
