Question about Philips 42PFL5332D 42 in. LCD Television
When i turn on tv red light comes on but no sound or picture?i
I was told the power supply was gone, how much will it cost to have repaired?
    Top Expert:
  • Philips Master
  • 74,198 Answers
If the power/standby light comes on, means, the power supply regulator board is working. The fault must be due to its main board. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. Checking method of power supply board is given.
Posted on Jan 04, 2014
4 Suggested Answers
  • 61 Answers
SOURCE: Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Posted on Nov 19, 2008
dsacco86
  • 1077 Answers
SOURCE: TV won't come on - get a blinking red light instead
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you the flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
Turn tv on has sound and picture then picture goes out and the red light comes on with fan
The red light usually indicates a power section problem. It would be something just about gone or overheating.
You will have to take this into a repair shop or a Phillips repair depot. You really should get an estimate for this before commiting to getting it fixed. Depending on the year it may have a sperate power board (cheapish to fix) or might require the main board to be fixed (lots of $$$) Worse case is that it can cost as much to repair as just buying a new replacement tv. So get the repair estimate and check around for replacement costs and let that be your guide as to which way to go with this.
Oct 10, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv fails to power on red light glows around power button on tv
there is somthing like puse in the back in side it cost u near about 200 $ put that it gone work 101percent
Dec 12, 2008 | Samsung HCN4226W 42" Rear Projection...
Troubleshooting akai 32
won't turn on, green light comes on and them click sound and goes red, never a picture. continues to cycle through this every ten seconds or so
Aug 25, 2008 | Televison & Video
Convergence repair cost
This repair will be around $300 to 400.
Apr 04, 2008 | Hitachi 57TWX20B 57" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Oct 24, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Power up problems
Does anyone know what the part number for this elucid power supply would be? My TV is doing the same thing, so I'm trying to find one so I can swap it out.
Apr 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Philips 42PFL5332D 42 in. LCD Television Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
