Question about ASUS MeMO Pad HD 7
Asus Memo Pad 7 will not turn on
Got Memo 7 for Christmas, looking forward to using often but now it will not tun on at all. totally black screen, not even sure if it is charging when plugged in. did not come with manual, not sure what to do maybe return it.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
It did work for a while? I've had occasions where I plugged in my tablet but it didn't charge because the plug wasn't seated correctly. Also I discovered it only worked with one of the cables I have even though any mini USB cable will fit. Do you have another cable you can try to plug into the unit
Posted on Jan 19, 2014
2 Suggested Answers
  • 508 Answers
SOURCE: My new Asus memo hd 7 will not turn on whatsoever.
Manual? They come with those? never got one with mine. Only thing i do if i am sure it is charged up is to hold the power button until the Google critter comes up. Might be the android one as well. Something comes up but that's all i do after shutting my down and telling it to power off.
Posted on Nov 04, 2013
I have a crack on my asus tablet what should I do?
Crack+touch screen not working usually means broken digitizer, which means replacement screen. Usually cost prohibitive in something like the Memo series.
Mar 03, 2015 | ASUS MeMO Pad HD 7
Can you fix a bad charging port on my asus memo pad 7
Asus seems to be having some serious issues with their memo pad and if yours is out of warranty doing it yourself may be your only option. There are a few videos on you tube about this problem so I would check them out. I had to open my Asus tablet when my cat knocked it on the floor and I had a black screen. Be aware that if you decide to fix your memo yourself that you need to be very, very careful every step of the way; take pictures, write notes...whatever you need. Good luck!
Aug 05, 2014 | ASUS MeMO Pad ME172V-A1-WH 7" 16 GB Tablet...
Asus MeMO Pad HD 7 won't turn on or charge.
Ah ASUS. I have a Memo 10. Had the same problem when it was 6 days new. Asus has a UI that is bad.
1. First try to charge via USB to your computer. If you get any result good, leave it a bit.
2. Leave it plugged in and see if it will turn on. If you can get it to turn on ... do this.
3. Find the back up and restore/factory reset. Back up your data, pics, music. etc.
4. Do a factory reset... it will say everything of yours will be delted. Proceed.
5. Restart the tablet.
6. Go into settings and TURN OFF Asus's UI. On my Memo 10, under settings is a menu called "Asus Customized settings" in the sub-menu turn OFF "Use ASUS Quick Setting" yours may say something a bit different.
7. Restart. The look will be different but no worries. On the upper right see if your tablet it charging. It will be a battery with green and black and a lightening bolt in it. If it is charging try your wall wart charger.
Jul 20, 2014 | ASUS MeMO Pad HD 7
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
How to change top glass of me173x?
Asus MemoPad ME172V Take Apart and Reassembly Nothing Left This is the basic way its done.If you'd like i can do its for you.Call 225-290-5733
May 25, 2014 | ASUS MeMO Pad HD 7 ME173X-A1-WH 16 GB...
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked. http://www.youtube.com/watch?v=PXcQgpISSi8
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
Black Screen no battery picture
If you are having this problem with the tablet, but the charger works fine with the cellphone, then mKe sure that you are using the right charger for the tablet, or it could be that the charging port in the tablet is damage, or the battery needs to be replace.
Mar 20, 2014 | ASUS MeMO Pad HD 7
My ASUS will turn on and show screen with ASUS logo but will not go to home screen it just stays loading
FINALLY RESET REQUIRED FOR THE TABLET, JUST PUSH THE RESET BUTTON ADAJACENT TO THE VOLUME BUTTON, WHICH WILL LOOK LIKE A PIN HOLE. INSERT AN JUMP CLIP FIRMLY BY STRAINGING IT AND WAIT FOR 10 - 15 SECONDS TO MASTER RESET. THEN ENJOY....
Feb 25, 2014 | ASUS MeMO Pad HD 7
My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
Nov 04, 2013 | ASUS MeMO Pad HD 7
ASUS MeMO Pad HD 7 Logo
690 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
